hello every one I already know what the code is I just need help on fixing it. its the A/F sensor heater (bank2). I did do a search and nothing came up.
what i meant to ask is were in the passenger side is this sensor?
Banks and sensors go like this:
Bank #1 - same side as cylinder #1
Bank #2 - same side as cylinder #2
Sensor #1 - sensors are numbered from the motor back. Sensor #1 first. Sensor $2 second.
If I'm not mistaken bank 2 is the drivers side bank 1 is passenger side. The sensor is before the catalytic converter. Correct me if I am wrong. Cylinders 1,3,5 are on the passenger side cylinders 2,4,6 are drivers side.
Oops. You are correct. It's been a while since I've seen the diagram.
