car will not start at all
soo heres the issue hopefully someone can help me out. when i go to turn on the car it will not start but at the flip of the switch the lights do work. it takes about 10 or more trys of putting my foot all the way on the clutch and turning the key unit it turns on. i dont seem to have a problem in the morning because it starts right up.. i called nissan but they said 210$ for the diagnosis, times are tuff right now and thats just out of the question. any help will be greatly appreciated! thank you
low battery? leak? failing starter? maybe a few more specifics IE: temperature, frequency? $210 is a bit steep for just a diagnostic, there are a few vendors on here that could poss give you better pricing , heard good things about specialty z. BTW sometimes the battery can still turn on the lights but not have enough power to crank the car. I think kragen check your battery for free and like $20 to charge it. GL bro.
There's a clutch sensor behind the clutch pedal that needs to be engaged in order for the engine to turn over. Sounds like it's gone bad.
If you don't have any voltage issue, this is the likely culprit. The part isn't expensive and you should be able to swap it out yourself. Good luck.
Is your car cranking at all? If not it could be a bad clutch pedal/neutral safety switch (behind the clutch pedal) or the battery not providing enough power for the starter to crank
no i just adjusted mine a lil more toward the pedal, then drove around for a while and re-started it at least 5 times with no problems, it may just be temporary but its working for now. switch is only $15 if it does go bad. you can press the switch with the car running and it wont do anything, i was worried about hitting while driving but nothing happened.
