VQ35HR (P0345) Cam shaft Sensor Bank 2 Error
Old Oct 3, 2009 | 04:35 PM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Default VQ35HR (P0345) Cam shaft Sensor Bank 2 Error
My car started to throw this code recently. I looked it up and it said that. I followed the procedure in the FSM, and tested both sides of my cams sensors. The passenger side had continuity on two of the three connections, while the other sensor on the driver side only had continuity on 1. I reset it, it hasn't come back yet, but that is what I found recently.
Has anyone else had this problem happen? When it happened is when my car was on the dyno, and it lost power after 6500 or so rpms and hit like a fuel cut. It also did it on the track.
Let me know. Thanks!
Old Oct 4, 2009 | 10:28 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Wow, great help this site is. lol
Old Oct 4, 2009 | 10:33 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
The sensor is dead. Replace it.
The either work or don't. You're still under warranty so get it done.
A faulty cam shaft pos sensor can cause long starts and stalls.
Old Oct 8, 2009 | 06:30 PM
Exodus751's Avatar
Exodus751
yeah don't clear the code take it to dealer they'll replace cam sensor under warranty can't remember bank2 front or rear if it's front it is piece of cake if it's rear little pain in the ***
Old Oct 8, 2009 | 06:32 PM
Jay'Z's Avatar
Jay'Z
Check the wiring, there is a green connector that goes to that sensor if I can recall correctly and it can fray or split the wiring easy...
If it is bad you will lose gobs of powa......
Old Oct 9, 2009 | 04:45 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
I checked the connectors, and they were fine. I even removed the sensors looked at them, and tested with my multimeter. One when it heated up went open on continuity. Which was Bank 2. That might be a issue.
Old Oct 9, 2009 | 04:52 AM
0jiggy0's Avatar
0jiggy0
You've nailed it. Some intermittent sensor failures only happen when the sensor heats up. Replace it.
Old Oct 9, 2009 | 06:12 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
I just ordered one.
Old Oct 9, 2009 | 06:14 AM
Jay'Z's Avatar
Jay'Z
Old Oct 9, 2009 | 06:33 AM
Motormouth's Avatar
Motormouth
the love I feel in this thread.
also: you are driving your car too awesomely which caused your sensor to fail.
Old Oct 9, 2009 | 06:59 AM
Tac-M's Avatar
Tac-M
i wonder if this has anything to do with the "sputtering" that some of us HR owners have until the engine is warmed up .....
Old Oct 9, 2009 | 10:51 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
^^ Dunno. Mine started to do that about 1 month ago, then this started happening.
Old Oct 13, 2009 | 04:55 PM
Tac-M's Avatar
Tac-M
this sux... imagine the future problems with vvel on the 3.7..... that ish is just too complex !
Old Nov 8, 2009 | 08:25 PM
NISMOFO's Avatar
NISMOFO
Question: did you replace the sensor? If so, was it necessary to "reset" or "reflash" the ECU after??? I have had two dealerships tell me it is necessary to "reflash" the ECU after changing out a camshaft position sensor. I have a hard time trusting dealerships though.
Old Nov 9, 2009 | 12:58 AM
pchio's Avatar
pchio
Those camshaft sensors are common problem on VQ motors, just replace it if u see that code.
Old Nov 9, 2009 | 04:13 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
I did, and it hasn't shown back up again. You have to reset the code in the ECU to clear it.
Old Nov 9, 2009 | 04:41 AM
NISMOFO's Avatar
NISMOFO
Thanks! That's what I needed to know. I had the bank 1 sensor replaced back in January at the dealership (my car died at the dealershp and wouldn't start). They told me it needed to be reflashed & not "reset". I tried to call BS on them, but I got nowhere. I can't find a single person who needed their car "reflashed" on the forums after changing the cam sensor.
Then yesterday my bank 2 sensor just started acting up....all the same symptons. P0345 code (bank 2 driver's side) this time instead of P0340 (bank 1 passenger side). My car is a 2003 model.
I'm going to replace the crank sensor as well while I'm at it.
Funny thing is that I wanted to replace all 3 sensors the first time this happened, just to be on the safe side. And both the parts guy & service advisor thought I was stupid and pissing money away. Well, this is the exact reason why I wanted to buy all 3 sensors back in January (the recall Nissan had replaced all 3 sensors).
I'm glad that I know what the issue is now and that it threw a P0345 code because I had hot start issues this past week and this explains it all.
Old Nov 11, 2009 | 04:52 AM
NISMOFO's Avatar
NISMOFO
I replaced my bank 2 sensor camshaft position sensor (P0340) and crankshaft position sensor on Monday. Car runs awesome now and does not hesitate to start like it had been doing for the last week.
Old Dec 14, 2009 | 09:59 AM
JjPadilla's Avatar
JjPadilla
hi z guys, im having the same problem. my z is throwing a p0345 code. replaced my battery but was still cranking long b4 starting up. also are any of u experiencing associated w/that problem, once my engine starts all 3,sevice engine, tcs, and slip light goes on and stays on. but my car idles fine and drives normal. no lost power or compression or signs of wanting to die out at all. any help would be great. thnx.
Old Dec 14, 2009 | 11:07 AM
NISMOFO's Avatar
NISMOFO
I have experience with this issue.....you need to replace the camshaft position sensor on the backside of the driver's side valve cover. It's just below the throttle body. It's easiest to get to the sensor from the passenger's side fender (backside of the motor). The part can be $70+ depending on where you buy it from.
The plastic clip that is connected to the sensor is a huge PITA to figure out the first time.
You'll need to unplug your battery overnight or clear out the codes manually (Google Technosquare's website).
This is not something I would pay a dealership to do.....they will charge you around $350 parts/labor. I paid a dealership to change out my sensor on the passenger side because they talked me into believing that the ECU needed to be reflashed (false).
FYI, I grew up outside of Chicago :-)
