VQ35HR (P0345) Cam shaft Sensor Bank 2 Error
thnx nismo.. qstn, so is it camshaft sensor bank 2 i need 2 replace? advanced auto parts is selling 2 types, angled sensor which i believe would b4 bank 1 passenger side n straight sensor for bank 2 drivers side. is bank 2 the type i would need 2 replace for the p0345 code? and last, and if it is bank 2 i need 2 replace can i access and change it from the top by taking out my intake throttle? srry 4 all the qstns, jus dont want my baby z 2 be ill anymore hehe..
http://www.courtesyparts.com/350z-pa...5_743_745.html
Bank 2 (P0345 code) means it's the driver's side sensor. I think it's a 10mm bolt that unbolts the sensor..and then it slides out. Getting it unclipped is the hard part. I think the clip pushes "in" towards the sensor...it's very hard to explain. I ended up getting frustrated and I pulled in intake tube off and pulled the wiring/sensor up and out "above" the motor so I could unclip it. It was more work than it should have been just to unclip it. But it is best to approach the whole removal/replacement from the passenger side fender (looking at the back of the motor).
I bought my sensor from a dealership to make sure I was getting the right part.
You are so spoiled that yours are at the front of your motor........I only wish mine were. When you can't see jack and you're trying to do this on the backside of the motor with little lighting/room...the clips can be frustrating. But once undone, I felt like an idiot on how easy they were to undo.
thnx nismofo!!! finally changes my camshaft 2day... THE CLIP WAS THE HARDEST PART! especially when ur hands are frozen haha.. started my baby up like butter.. thnx again nismo! now jus need 2 figure out if im gonna buy snow tires from tire rack or buy a used honda beater from now on during the 6mnths of winter season? hmm decisions decisions..
