I need help with my damn 350z....
Old Dec 1, 2009 | 09:18 PM
orangeflash's Avatar
orangeflash
Default I need help with my damn 350z....
1. My SES light was BLINKING tonight when i got started down the road and then turned off about 20 seconds later. This just happend and now when im driving it seems to be fine. I have almost 100k miles and im wondering what the hell this means!
2. My damn driver side door lock is not unlocking correctly and the toggle is getting stuck midway. I now have to enter my f*cking car through the passenger side. Any ideas???
Old Dec 2, 2009 | 01:49 AM
duro78's Avatar
duro78
that sucks especially if people are around gl
Old Dec 2, 2009 | 05:42 AM
How many OBDII codes are there that will trigger a check engine light? 20? The best I can do is a guess.
Old Dec 2, 2009 | 05:48 AM
KornerCarver's Avatar
KornerCarver
Possibly some anger management classes would do you some good. The car has almost 100,000 miles and you are mad about a couple minor issues. Just get them fixed and move on with your life. Getting upset and using expletives will just raise your blood pressure.
Old Dec 2, 2009 | 05:50 AM
JasonZ-YA's Avatar
JasonZ-YA
1. SES LIGHT:
yeah, the next time the light comes on head to autozone or a local autoparts store that can run the code for you......
from there if its not clear, post it up and maybe someone can help you with experience on the matter...
2. DOOR LOCK:
Lithium based lubricant - your car has age on its side, the factory greese has probably broken down.......if the electronic mechanism is still working via key fob but the toggle isnt opening all the way i would say try lube'n up the hardware...
-J
Old Dec 2, 2009 | 08:18 AM
Blck350z's Avatar
Blck350z
A little lube never hurts
Old Dec 2, 2009 | 08:47 AM
stormcrow's Avatar
stormcrow
a blinking SES light usually means a misfire. this is usually pretty serious, so i would visit the dealer.
Old Dec 2, 2009 | 06:45 PM
orangeflash
ok... i was mad at the time... not so much now...
Anways, I put my key in the lock and turned it really hard to see what would happen. If finally gave way and the door is now working ok.
Hey KornerCarver, how do you like Saint Louis???
Old Dec 2, 2009 | 07:10 PM
0jiggy0's Avatar
0jiggy0
A blinking SES light means a misfire that has the capability of damaging the cat. The more you drive it the more chance your going to need to replace the cats.
Old Dec 2, 2009 | 07:26 PM
JasonZ-YA's Avatar
JasonZ-YA
spray some lube all up in there......key hole and all..
-J
Old Dec 3, 2009 | 09:48 AM
ms350z's Avatar
ms350z
Also see this thread https://my350z.com/forum/maintenance...-whats-up.html
Old Dec 3, 2009 | 06:49 PM
orangeflash
^^ Thanks
Old Dec 10, 2009 | 09:07 AM
orangeflash
wow, now i am locked out of my car... both locks keep malfunctioning. They both will not unlock. It sounds link they whine when i hit the unlock button. And also no luck when i put the key in the door and turn. DOES ANYONE HAVE THIS PROBLEM????
Old Dec 10, 2009 | 09:17 AM
JasonZ-YA's Avatar
JasonZ-YA
did you ever lube them?
-J
Old Dec 10, 2009 | 09:09 PM
orangeflash
Today I took the driver side door apart to see if i could get to the lock mechanism. Man, what a pain in the A$$! It looks like the previous owner had someone in there jimmy-riggin' some wires. Anyways, i sprayed all kinds of lube all over the mechanisms by the lock and it seemed to be working fine. I guess i'll find out soon enough.
Old Dec 13, 2009 | 12:25 PM
orangeflash
Well I had my friend help me out with his reader and we found out that im getting random misfires and also cylinder 6 misfires. However, there were no codes that showed up.
Old Dec 13, 2009 | 05:05 PM
ms350z's Avatar
ms350z
I don't understand, how did you determine random and cylinder 6 misfires if no codes are showing up? You said earlier your SES light was blinking, so obviously there are codes... That being said, I would start by tracking down the issue on cylinder 6, most likely a bad spark plug coil or bad/clogged injector on that cylinder. After that issue has been fixed, clear the codes and see if the random misfire code returns.
Old Dec 13, 2009 | 06:48 PM
orangeflash
well, his reader only said, "Random misfires" and "cylinder 6 misfire"... so i guess those are the codes? So im gonna replace the spark plugs since i'm almost at 100k miles.
Old Dec 14, 2009 | 05:20 AM
ms350z's Avatar
ms350z
That would be codes P0300 (random/multiple cylinder misfire) and P0306 (cylinder 6 misfire). Replacing the spark plugs as you mentioned is definitely a good idea if they have been in there for 100k miles, but there is a good chance this won't fix the codes you are getting. I am betting on a bad coil or injector in cylinder 6. Start with the spark plugs since they need replacing anyway, have your friend clear the codes, then drive 50+ miles and see if the code comes back.
Old Dec 14, 2009 | 02:25 PM
Boogshag's Avatar
Boogshag
I had engine light and code for cylinder 4 misfire, then a code about 40-50 miles later that had to do with the cat, but wasnt specific and I cant remember the code. This coming off of repairing this salvaged 06 MT Z, could these be clues its an oil consuming Z and my life will get much worse?
OP- Sorry for straying off topic a little
