Best transmission oil for my Z?
Old Jan 21, 2010 | 12:13 PM
Bevo's Avatar
Bevo
Originally Posted by Bigalow
Bevo,
Is that the same as the stock fluid? My trans pedal gets stick when my fluid heats up (high rev'ing/hot summer days). Apparently, that fluid can't handle high heats. I'm looking for something syn and reliable.
Yes, I use the stock nissan manual tranny fliud. I live in Texas, it gets to 100+ F in summer, but never has any problem with my tranny.
You said pedal gets stick, do you mean the clutch? then you probably need to check your clutch fluid.
Old Jan 21, 2010 | 01:19 PM
Bigalow's Avatar
Bigalow
Wait. I thought the tranny fluid was the same as the clutch fluid..
Old Jan 21, 2010 | 01:46 PM
dmroberson's Avatar
dmroberson
Originally Posted by dkmura
50/50 mix of Redline MTL/MT-90. Meets Nissan viscocity requirements with friction modifiers that help synco operation. I use it in both my street and SCCA 350Z race cars.
+1. I'm on my second tranny/diff oil change. Used Redline MTL/MT-90 mixture again.
Old Jan 21, 2010 | 03:10 PM
tw8715's Avatar
tw8715
first i had the OEM tranny fluid. Then changed it about 20k ago with amsoil.
i wanna try redline to see if it lives up to its hype.
honestly i couldnt tell the difference between the OEM fluids and amsoil fluid in the car.
Old Jan 21, 2010 | 04:24 PM
mistanismo's Avatar
mistanismo
No. the clutch uses brake fluid.
Old Apr 2, 2014 | 01:48 AM
Z33KLF's Avatar
Z33KLF
Redline MTL&MT90 50/50 is the best choice!!!
Old Apr 2, 2014 | 04:48 AM
350zchad's Avatar
350zchad
OEM.. I trust the Japanese engineers
Old Feb 25, 2020 | 05:00 PM
Hongboum Lee's Avatar
Hongboum Lee
So do both of them have to be 75w90 or like what? Makes no sense
Old Feb 25, 2020 | 07:17 PM
dkmura's Avatar
dkmura
General & DIY Moderator
You're reviving a thread that's almost a decade old. Redline now produces MT85, so no need to mix Redline fluids any longer. MT85 fits Nissan specs .
Blair Kellner
Aug 15, 2017 09:40 AM
Nissan919
Dec 25, 2008 11:57 AM
Spoiled Z
Aug 30, 2006 09:56 AM
VeilsideZ33
Sep 11, 2005 05:40 PM
