Dealer wants $550.00 + tax for 30,000 Mile service.
So I just got back from the dealership after they had replaced my seat cushion for an air bag sensor malfunction and I had asked the tech about the 30,000 miles service. Apparently he just went through a list full of inspections and things I know I didn't need to do right away. It's cold as hell outside this season and I just wanted to know what you guys would recommend having the dealership do.
I'll save some of the DIY things for when it gets warmer but what items are the necessary items I should have them do such as engine oil and things like that.
Thanks in advance. This is for an 07 350z.
firstly... never do anything but warranty work at the dealer.
secondly, regular oil changes and air filter cleanings are about it.
$550 m y a s s
will let another chime in, but belts and fluids are at 60k i believe
$550 m y a s s
30k.....what do they want u to change??? everything should be good unless u ran ur breaks down or wasted ur rear wheels already? spark plugs/trans/rearend fluid/belts dont need to be changed so what do they want to do ?
If you search u will find here a complete list of the 30k requirements and you can do them yourself for under $75.00 as most here online have done. I beleive u will also find the same info in your owners manual also.
