problem with power locks
Old Jan 13, 2010 | 11:54 AM
03BlkZ's Avatar
03BlkZ
Default problem with power locks
The power lock on my driver side door doesn't seem to be working. It doesn't work with the remote or the button in the car, anyone know what this could be?
Also my hatch release button doesn't work, the only way to open the hatch from the outside is to hold the button and pull up on the hatch right when it unlocks.
Old Jan 13, 2010 | 04:55 PM
duro78's Avatar
duro78
blown fuse?
Old Jan 13, 2010 | 05:05 PM
DB350's Avatar
DB350
Run some wd-40 up in the baatch
Old Jan 23, 2010 | 11:09 PM
03BlkZ's Avatar
03BlkZ
bump
Old Feb 15, 2010 | 10:42 AM
03BlkZ's Avatar
03BlkZ
Bump, would like to get this fixed. The power lock in particular so I can stop having to use my key in the door every time I go to my car. Have tried searching both on here and google. No luck so far.
Old Feb 15, 2010 | 07:58 PM
MTZ33's Avatar
MTZ33
did u check the fuse? i had the same problem and it was the fuse since the door and hatch locks run in the same circuit.. try fuses #18 and #21...
Old Feb 16, 2010 | 08:47 AM
03BlkZ's Avatar
03BlkZ
I will check, but wouldn't the passenger side also not work if the fuse was blown?
Old Feb 16, 2010 | 08:36 PM
MTZ33's Avatar
MTZ33
hmm.. check the fuses regardless.. if its not that, check for any crimps on the door lock wires (driver side), could of created a short to voltage by mistakenly crimping the wires somehow.. also as stupid as it would sound, try n reset ur ecm.. these cars tend to act up in wierd ways..
Uriyo_
Sep 8, 2021 08:46 AM
