350z OEM Flywheel bad design?
Old Jan 30, 2010 | 07:54 PM
SatchScream's Avatar
SatchScream
Default 350z OEM Flywheel bad design?
I took my car to a local mechanic for some clutch maintenance and he says my flywheel is about to go. My car is a 2003 base model Z with 104K miles. He said the OEM flywheel that comes on earlier Z/G's are poorly designed and go bad frequently, he also said they 'redesigned' it for the newer ones and that they're much better now.
I've never heard of anything like this, I have searched Google and these forums and have not come up with anything. So is he right? Does the OEM flywheel suck?
Old Jan 30, 2010 | 08:13 PM
Gibbs's Avatar
Gibbs
Know it all
Yes it's terrible
Old Jan 30, 2010 | 08:19 PM
SatchScream
Old Jan 30, 2010 | 09:15 PM
Ban all "My mechanic said...” threads.
Old Jan 30, 2010 | 09:21 PM
$LiK RiK's Avatar
$LiK RiK
^+1
Old Jan 30, 2010 | 09:45 PM
SatchScream
So is that a yes it does or a no it doesn't?
Old Jan 30, 2010 | 10:06 PM
shiftdrift06's Avatar
shiftdrift06
NO your mechanic is full of shiet. if your flywheel IS going out, just get it resurface.
Sounds like he tryna hustle you..like any other "mechanic"
Old Jan 30, 2010 | 10:08 PM
Emski's Avatar
Emski
I have one of the rare mechanics that tells me "nah you don't need this...probably not that also..."
Old Jan 30, 2010 | 10:42 PM
SatchScream
Yeah like I said, never heard of any of our flywheels being flawed, just thought I'd double check with everyone here.
Old Jan 31, 2010 | 06:28 AM
NismoZ123's Avatar
NismoZ123
Talking Flywheel WAT??!?
pics or we will lose all interest
Old Jan 31, 2010 | 08:30 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
you can't resurface the Z's flywheel, due to it's design
to the OP - I've never once heard of OEM flywheel issues. Perhaps he meant OEM thow out bearing issues, as those are quite common (they tend to be noisy, though I've never seen one fail first hand)
Old Jan 31, 2010 | 08:40 AM
KornerCarver's Avatar
KornerCarver
If the flywheel lasted 104,000 miles, the design can't be "that bad". Just get it fixed and move on.
Old Jan 31, 2010 | 05:18 PM
sno's Avatar
sno
What is this clutch maintenance you speak of? If you had the clutch replaced, you need to replace the flywheel as well. Like Z1P said, the OEM flywheel can't be resurfaced.
Old Jan 31, 2010 | 05:32 PM
SatchScream
Well I had it taken there to get the clutch line bled as there was no pressure in the pedal, no actual clutch issues, though, no slippage or anything like that.
Old Jan 31, 2010 | 08:49 PM
drivessidewayz's Avatar
drivessidewayz
Imo resolve all your issues and go aftermarket
