clutch PEDAL "POP" when releasing
Old Feb 10, 2010 | 08:38 AM
labelworkshop75's Avatar
labelworkshop75
I have an 06. It did it about 10 times total. Have not heard it in a while now. It's not the tranny or clutch. Its def. the pedal assembly, prob the spring as mentioned earlier
Old Mar 18, 2010 | 07:50 PM
jasabeast's Avatar
jasabeast
my 06 does the same thing... i just ignored it.. still pulls hard with no slipping
Old Mar 21, 2010 | 04:15 PM
HokieZ's Avatar
HokieZ
My G35Coupe has the same problem. It does it constantly and is annoying the hell out of me.
Old Mar 21, 2010 | 04:36 PM
stylett9's Avatar
stylett9
it's the plastic pedal. Nothing you can do about it. If you press hard enough on the foot rest on the far left you can make the same popping sound. You just get used to it.
Old Mar 21, 2010 | 05:14 PM
toeveryhour's Avatar
toeveryhour
i have the same issue. '05 with 55K on it
Old Mar 24, 2010 | 06:58 AM
raymondcleung's Avatar
raymondcleung
I have the same problem with the "pop" noise, I bring it to the dealer and they replaced the clutch pedal assembly for me. They said it's the pin making the noise when the pedal is engaging. After that, no more noise!
Old Mar 24, 2010 | 06:07 PM
gyotar's Avatar
gyotar
Its the pedal assembly. Watch for it to get worse possibly turning into a sticky pedal.
Old Mar 27, 2010 | 04:16 PM
treefittyz33's Avatar
treefittyz33
mine just started doing this a couple days ago, was wondering what it could be its really annoying, ill bring it in to nissan this week
Old Apr 18, 2012 | 12:21 PM
Lee_base06's Avatar
Lee_base06
Hey I just bought my 06z and mine pops for the majority of the time, Only when I'm depressing it tho. I've heard it's completely normal but if it was normal you would think it would happen consistently which it doesn't. I've also heard its a throwout bearing, which makes more sense.
Old Apr 18, 2012 | 06:31 PM
Golden_Armz's Avatar
Golden_Armz
yup, mine does it too. i have a 06. sometimes when it gets hot, it will stick after the engage point, and then POP back up. trying tp find a soultion. idk if i have the warranty so dont want to pay the dealer to get it fixed.
Old May 10, 2012 | 11:39 AM
frivolous_'s Avatar
frivolous_
Mine started sticking, about the last inch then kinda shoots out. same issue? little grease or new assembly, makes me absolutely hate the clutch.
Old May 10, 2012 | 05:12 PM
Clon3's Avatar
Clon3
I think what you are experiencing is the little rubber piece that pushes into the Cruise Control switch on the clutch assembly pedal. Mine does this all the time and eventually the rubber piece just fell out and the clutch is actually smoother now. I don't care about Cruise Control as I don't use it at all.
Old Jun 5, 2012 | 09:27 AM
El gurple's Avatar
El gurple
I got an 08 gt and my clutch completely stayed to the floor last night and couldn't go into any gears?...had to get it towed to my house...and now its at Nissan...better be covered under warranty...I'm at 52k miles...2nd time I take it in for sticky clutch...but last time it was still drivable?...
Old Jun 5, 2012 | 12:58 PM
El gurple's Avatar
El gurple
Yep Nissan is replacing the master cylinder under warranty....is there anything I shud look for after I get car back?..anyone else expierence problems after they 'thought' they fixed the sticky clutch....and a lil upset as I used stoptech fluid and I know dealer will use factory...grrrr...hate bleeding process
Old Jun 8, 2012 | 01:40 PM
ronn1's Avatar
ronn1
Originally Posted by Cass_Epp
I have had my z for about 5 months now, just hit 6000 miles. Recently started noticing that once in a while when I am RELEASING my pedal it makes a really annoying "pop" noise. Anyone have any idea why it does this and how to make it stop. It's realllly annoying.
I know this an old thread..but the problem is pretty prevalent and I thought I'd revive it.
I had a similar problem...makes more of a *clicking* under the pedal. I got spray white lithium grease (Gunk). You have to get WAY up above the spring where the rod is.
See this post of mine here on the issue:
https://my350z.com/forum/9446208-post6.html
Old May 7, 2013 | 08:58 AM
Deteria's Avatar
Deteria
I need to get this fix done. I get that popping sound only when in gear and releasing the pedal. If I push on pedal and release in Neutral, it's fine.
Old May 17, 2013 | 07:55 PM
Deteria's Avatar
Deteria
I've been having this ongoing popping sound for like 1-2 years of ownership of my Z. I sprayed that lithium grease and it fixed it (I think). Gonna go for a drive tomorrow morning and find out :O but as of just using my hand and foot pushing the pedal, it stopped making the popping noise.
Old May 20, 2013 | 01:01 AM
  #38
alby13's Avatar
alby13
my pedal would come up almost all the way, then POP. it would do it sometimes and sometimes totally normal.
i flushed the clutch fluid with suction, then pumped it and did a manual bleed, flushed all the dirt out with suction again, then bled it manually again. now the clutch pedal is super smooth, comes back really strong, fast, and smooth. no sticking and no popping.
Old Jun 4, 2013 | 11:50 AM
  #39
HK350 Z's Avatar
HK350 Z
The lithium grease worked for me as well was having the noise as I released the clutch pedal...got some of the same grease from autozone,drove to a taco place to eat,stopped and ate, came back and drove back to work with no noise.
Old Jun 5, 2013 | 10:37 AM
  #40
GremmZ's Avatar
GremmZ
Where exactly do you apply this lithium grease? (Nevermind - Saw Ronn1's Link above, includes a picture and everything. lol)
I've had this issue now for a few months, at first just dealt with it. Now i'm going crazy listening to it. Doesn't do it everytime, but it does it enough to be a problem for me.
It is a popping/clicking sound when releasing the pedal. Sounds like the clutch pedal assembly for sure. No sticking clutch though, just the noise when releasing.
To make matters worse, my clutch is shuddering now when launching from first (casually). Feel the damn car shake a bit.
