clutch PEDAL "POP" when releasing
Old Feb 2, 2010 | 06:35 AM
Cass_Epp's Avatar
Cass_Epp
Default clutch PEDAL "POP" when releasing
I have had my z for about 5 months now, just hit 6000 miles. Recently started noticing that once in a while when I am RELEASING my pedal it makes a really annoying "pop" noise. Anyone have any idea why it does this and how to make it stop. It's realllly annoying.
Old Feb 2, 2010 | 06:45 AM
TheFarmer's Avatar
TheFarmer
Where's the noise coming from? Pedal assembly? Transmission area? Engine area? Differential?
Old Feb 2, 2010 | 07:03 AM
diablox1's Avatar
diablox1
mine has done that or something similar in the past too. i wouldn't say mine makes a "pop", but more of a relatively loud click. did it for a couple of thousand miles and went away. pooof.... dissapeared. sound comes from the direct pedal assembly area.
Old Feb 2, 2010 | 08:09 AM
abeklipse's Avatar
abeklipse
My 04 does this from every now and then. Sometimes its a click or a creaking sound.
Old Feb 2, 2010 | 08:22 AM
TJGILROY's Avatar
TJGILROY
same here! still runs great, though
Old Feb 2, 2010 | 08:42 AM
ckthepilot's Avatar
ckthepilot
My Z sounds like a Nascar but everything is fine.
Old Feb 2, 2010 | 11:25 AM
bluz370's Avatar
bluz370
My 2009 370 does this... WTF nissan
Old Feb 2, 2010 | 11:49 AM
SniperHunter's Avatar
SniperHunter
Probably just the cold weather.
Old Feb 2, 2010 | 03:06 PM
xenonZ's Avatar
xenonZ
Mine pops and squeeks sometimes to very rare though. I have had this happen on hot days asell.
Old Feb 2, 2010 | 04:55 PM
mywit's Avatar
mywit
my 06 dose it since i have had it.
Old Feb 3, 2010 | 04:35 AM
cheshirecat79's Avatar
cheshirecat79
It's normal, it's just the clutch engaging. Our tranny and clutch/flywheel assemblies are pretty loud.
Old Feb 3, 2010 | 04:45 AM
Cass_Epp's Avatar
Cass_Epp
TheFarmer, it's from my pedal. I guess if it's no harm to anything I'll just learn to ignore it..
Old Feb 3, 2010 | 06:03 AM
dragonfire6's Avatar
dragonfire6
Default ....
If you notice the pedal is making the noise again, try to feel with your foot if the pedal is smoothly coming all the way back out or if it is getting hung up the last 1" and then "popping" all the way out...
Mine has done this before and I added some oil/grease to the pivots/springs and now, no more popping sound
Old Feb 3, 2010 | 03:11 PM
T-Stan's Avatar
T-Stan
i had the same problem in my 08 nismo, took it into the dealership they checked it out, and they said it just a characteristic of the clutches. not much they could do.
Old Feb 3, 2010 | 03:23 PM
temoku's Avatar
temoku
Lol, BS! It's the spring on the clutch pedal. It's sooo freakin anoying too. You have to change the whole pedal assembly. If you or a previous owner tried to adjust yur clutch pedal it will make this 'pop' or 'tick'. It is 100% the spring, and make nissan change that thing. They did mine and it went away completely.
Old Feb 5, 2010 | 01:17 PM
SLIdEwAyZ25's Avatar
SLIdEwAyZ25
whever i got my 350z used the clutch pedal assembly wasn't tightend all the way to the firewall tightend it up and the poping noise went away.
Old Feb 5, 2010 | 04:16 PM
zman_tony310's Avatar
zman_tony310
Default pop sound
that "pop" sound you are describing that occurs when disengaging the clutch is most likely the pilot bearing on the car. I work at a performance shop and i have fixed this same problem on 2 separate occasions already.
Old Feb 5, 2010 | 04:49 PM
Z1NONLY's Avatar
Z1NONLY
Can it cause intermitent problems?
How do you troubleshoot this?
Is it expensive to fix?
Old Feb 6, 2010 | 08:05 AM
temoku's Avatar
temoku
lol. I don't know what kinda "pop" you are hearing but the pop I'm getting is from the spring on the clutch pedal. Just listen where you hear the pop coming from, it's pretty obvious if it's the clutch spring
Old Feb 10, 2010 | 08:30 AM
utlord's Avatar
utlord
i got the same prob, think temoku is right, that pop, hell you can feel it in the clutch pedal, push it in with your hand and listen, and since its loud not baffled its got to be something in the assembly, its is pretty annoying...
