anyone else having issues with 07 5th gear grind?
Old Feb 23, 2010 | 03:48 PM
kennedy's Avatar
kennedy
getting my trans replaced so I am not worried about it.
Old Feb 23, 2010 | 04:19 PM
Zomgfast123's Avatar
Zomgfast123
only happened to me once, shifting fast/hard from 4th to 5th, def my fault tho haha 07 eth. 47k miles
Old Mar 9, 2010 | 08:33 AM
westpak's Avatar
westpak
SFZCC
I have a quick question, I have to take my son's 07 Z in, I was going to just get the cylinder TSB done but he tells me he is having grind when downshifting from 6th to 5th, so they said they might change the tranny if needed.
My question is if you also got a new clutch with the new tranny? The dealer is telling me no but when I had mine changed on my 03 it came with a clutch
Old Nov 7, 2011 | 03:51 PM
pbn85's Avatar
pbn85
bump.
My cousin and I have 07 Z's, both stick. I have 63k miles and he has 70k, but while we were in his car yesterday he downshifted into 5th from 6th (around 50mph) and there was an audible scratching noise, I guess you can call it a grind. We figured it was due to user error. Anyway, he called me today and said it happened two more times downshifting into 5th gear.
I took him to my mechanic who I trust with all my cars. not only is he extremely knowledgeable but honest too. Rather than buy a used low mileage unit (because they arent really tested properly to ensure 100% working functionality), he suggested replacing the 5th gear synchro. Dropping the tranny, doing the synchro work is coming out to around $800 including the new nissan synchro.
I want him to make the right move...is replacing a synchro the best way to go presuming its done by a very competent shop? Buying a new unit isnt an option as it is too much for him.
EDIT: It seems like its only a downshifting issue into 5th from 6th. Upshifting into 5th is butter.
Old Nov 10, 2011 | 02:55 PM
Nismo1534's Avatar
Nismo1534
08 HR here. Received my first 5th gear downshift grind around 25K miles (only when cold). Had transmission replaced under warranty. It's been about 5k miles on the new transmission and I now have the exact same issue. Is this a known weak point for our transmissions?
Old Nov 10, 2011 | 04:37 PM
stock07g35s's Avatar
stock07g35s
Trans was replaced here on an 07. Frist 6th gear was crunching, then eventually 5th. Replaced trans at 20k I think, I am at 95K now with no trouble.
Old Nov 12, 2011 | 03:30 PM
pbn85's Avatar
pbn85
could it be that you're not rev matching? That would be easier on the synchros.
Old Nov 13, 2011 | 03:30 AM
Lawn Dart's Avatar
Lawn Dart
Be careful, I had the 5th gear grind. One day, it didn't come out.
Old Nov 13, 2011 | 06:32 AM
pbn85's Avatar
pbn85
what gear oil are you all using? I did a search here and most who have grinding issues are not using the Nissan 75w-85 MTF. Even using 75w-90 Nissan MTF caused issues with some people's transmissions and I read about a TSB stating Nissan dealers should only use 75w-85.
Old Nov 25, 2011 | 04:26 PM
Lawn Dart's Avatar
Lawn Dart
http://www.redlineoil.com/product.aspx?pid=140&pcid=7
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
