is the window seal replaceable?
Old Feb 21, 2010 | 12:07 PM
ares's Avatar
ares
Veteran
Default is the window seal replaceable?
03 coupe, the plastic seal which butts up against the window has cracked up where it connects to the metal roof. as a result there is wind noise and water getting into the car.
its not a matter of the window not sealing, as it is, the leak is above that.
I cannot seem to find a replacement part for this though.
Old Feb 21, 2010 | 12:10 PM
TheFarmer's Avatar
TheFarmer
Here ya go. Click on the corresponding weather strip side you need
http://www.courtesyparts.com/350z-pa...5_846_848.html
Old Feb 21, 2010 | 03:07 PM
ares's Avatar
ares
Veteran
I assume its the weatherstrip, not the retainer? I didnt realize it was all 1 peice running down the pillar, but thats fine, just want to be sure.
any hints, will I need any of the other bits? am I likely to break anything? I know alot of the plastic peices are pretty brittle after 8 years.
Old Apr 5, 2010 | 03:37 PM
Travic's Avatar
Travic
So did you ever find the seal you were looking for? Ive been looking as well for my CF A-Pillars and nissan doesnt sell them and i havent found anything close to what would look stock or a good fit for that matter. Ive contacted several sites and nissan they all say they dont sell that piece.... Anyone out there replace you seals on the roof pillar down to the hood?
Old Dec 12, 2011 | 02:00 AM
coanan's Avatar
coanan
Bringing it back to life anybody know? Thanks
Old Dec 13, 2011 | 10:57 AM
350z>S2k's Avatar
350z>S2k
just replaced my a pillars and I have a better understanding of the weatherstripping, so what exactly are you talking about? if you could post a pic that would be the best way to help.
chris
Old Dec 15, 2011 | 05:07 PM
coanan's Avatar
coanan
Looking to replace the rubber seals around outside A-pillars, wiper valance, and around windshield. It seems all the 350Zs I've looked at have the same problem. thanks
Old Dec 19, 2011 | 05:39 AM
350z>S2k's Avatar
350z>S2k
yes the interior seal along the pillars is replaceable. it pulls right off of the metal bracing it's attached to. the windshield seals I believe are glued in and can only be replaced with a new window. the small thin trim along the roof beside the a pillars is attached to the a pillars all along it and follows the pillars to beside the windshield. So to replace the small thin trim and trip on the right and left side of the windshield, you would have to replace the a pillars. and the trim along the top of the windshield can only be replaced when new windshield is installed. I hope that helped? let me know
Old Dec 20, 2011 | 05:01 AM
coanan's Avatar
coanan
Thanks, that's what I found out also, close to 300.00 per side for the outside A-pillar. I see most Zs have the same problem; I'm surprised no one has come up with a cheaper way to fix this. I'll keep looking, may find other cars with the same rubber seal that can be had cheaper.
Old Dec 20, 2011 | 10:42 AM
350z>S2k's Avatar
350z>S2k
I actually have a driver side a pillar for sale in the market place if your interested. the seals are good except on the very end of it where it touched the bottom right of the windshield. I can take more pics if needed. it's silverstone. 120$ shipped let me know man. if not, I was glad to help
Old Sep 16, 2012 | 03:16 PM
ninevoltz's Avatar
ninevoltz
I have this same problem, I'm gonna try filling it with black RTV.
Old Oct 27, 2012 | 02:18 PM
Dude1312's Avatar
Dude1312
did this work?
Old May 20, 2013 | 07:35 AM
ninevoltz's Avatar
ninevoltz
Yes, it worked. I'll try to take pictures today.
Old May 20, 2013 | 03:52 PM
ninevoltz's Avatar
ninevoltz
This is almost a year later:
Old May 20, 2013 | 07:54 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Hmm, shame about the match, but leak sorted?
Old Jun 3, 2013 | 09:43 AM
ninevoltz's Avatar
ninevoltz
Yes, no more leaks as far as I can tell.
Old Oct 31, 2013 | 02:45 PM
aicsusa's Avatar
aicsusa
Default New rubber seals!
I GOT THE A PILLAR WEATHERSTRIP THAT NO ONE ELSE HAS! I just repainted my car and took it all apart to do the paint job. When I went to put the a pillars back on I noticed how bad the weatherstrip was. As I looked online for a new weatherstrip I found many are looking for these but no one had them anywhere.
I made this weatherstrip for the 350Z a pillars! Very close to original. See the attached pictures!
Picture #1 shows the weather strip installed
Picture #2 shows the sealing and angles of the new rubber
Picture #3 shows the channel the a pillars sit in to keep the weather strip secure without having to glue it in, but we do recommend you do glue the new seal to the a pillar only! Do NOT glue the seal to your roof or window!
Picture #4 shows the difference in size between the old and new seals. Beware the new seal is slightly different in size.
I do not think you will not find anything closer to original than these! They are not half ***! They fit great and they are easy to install. They work excellent and look like new!
Any Questions? Email me at aicsusa@yahoo.com
Thank you for reading my post!
Several people have already asked me if I will make more of these for them. The answer is Yes! I will make more if someone wants to buy them!
Attached Thumbnails is the window seal replaceable?-iphonepics-1722crc1.jpg   is the window seal replaceable?-iphonepics-1726crc.jpg   is the window seal replaceable?-iphonepics-1730crc.jpg   is the window seal replaceable?-iphonepics-1724r.jpg
Rev_Night
Nov 7, 2020 06:00 PM
350z82
Oct 1, 2015 06:25 PM
pr_350z
Oct 1, 2015 05:03 PM
