My heater doesn't work at low speed
Old Feb 26, 2010 | 06:54 PM
gtstephenson's Avatar
gtstephenson
Default My heater doesn't work at low speed
My heater seems to not work when driving at low speed even when the temperature is normal in the engine. I think that the water pump fails to circulate water thru the heater core when the RPM's are down. But get on the freeway and there is plenty of heat.
Anyone else have this problem?
2003 Z MT w/ 96K miles (daily driver).
Tom Stephenson
Old Feb 26, 2010 | 07:13 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
most likely a bubble in ur cooling system. theres a ton of threads on how to fix it hope this helps.
Old Feb 26, 2010 | 07:21 PM
SatchScream's Avatar
SatchScream
Just floor it when you're cold.
Old Feb 26, 2010 | 08:02 PM
Waiz's Avatar
Waiz
I LOL'd!!
Old Feb 26, 2010 | 08:05 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Thermostat?
Old Feb 26, 2010 | 09:00 PM
JAM3Z's Avatar
JAM3Z
Phenom
Originally Posted by TreeFiddyZee
Thermostat?
Highly unlikely. Its a bubble in the cooling system I think...
Old Feb 26, 2010 | 09:34 PM
MrKaira's Avatar
MrKaira
Really MrZ31
Could be a bubble or your water pump. You also could just be low on coolant. My DD just had this problem and even though it wasn't overheating it still would only blow out hot air when it was moving.
Check the simpler things first!
Old Feb 26, 2010 | 09:36 PM
GHOST1207's Avatar
GHOST1207
Definitely air in the cooling system, try these steps and report back.
https://my350z.com/forum/8027649-post3.html
Old Feb 27, 2010 | 04:28 AM
How about medium speed?
Old Feb 27, 2010 | 05:42 AM
JCat's Avatar
JCat
On a hot day, my air conditioner blows warm air, unless the engine rev's are up and I am driving around.
I am not sure these problems are related.
I took it to a Nissan dealer and they said my problem was caused by a faulty sensor in the heater box. They wanted $600 to fix it. I have not pursued it yet....as I am unconviced.
Chris350z03
Oct 8, 2023 07:19 PM
bcoffee20
Nov 19, 2015 06:39 PM
Tomek350Z
Suspension
Oct 11, 2015 08:32 AM
Shane86
Sep 17, 2015 05:33 PM
AngryZ
East Canada
Sep 16, 2015 05:08 PM
