How I fixed my rear suspension CLUNK / NOISE....for $4
Old Jul 25, 2012 | 07:07 PM
  #61
nismo542's Avatar
nismo542
Glad to see that this little fix is working for you guys. Almost 2.5 years since I did this and it is still good to go.
Old Jul 31, 2012 | 07:12 AM
  #62
labelworkshop75's Avatar
labelworkshop75
Why hasn't this been made a sticky? Mods?
Old Aug 9, 2012 | 11:04 AM
  #63
USMChris's Avatar
USMChris
Great write up. I had the same thing start yesterday and wondered what it was
Old Jan 25, 2013 | 06:31 PM
  #64
08EG's Avatar
08EG
Originally Posted by JDMStanced
i just finished this DIY. The squeeking noise is still there but it was reduced by a lot with the gasket.
FOr the shock bolt spacers, Stance gr+ true style has different hole sizes! Ex. on the left coilover, there are two bolt holes in the shock bracket for a bolt to go through them, right?
One hole has .502" diameter and other hole is 5/8" diameter (what OP mentioned). My 5/8" diameter CPVC pipe cant be installed in .502" diamter.
Thanks for posting your results!! So the 5/8 pvc pipe could not fit (can't) be installed in the .502 diameter? Or it did work?
Did you also try to use the expanding spray foam into the cavity above the shock? I think that was supposed to be very helpful. I wonder if it is even more helpful than the spacer?
Old Jan 25, 2013 | 06:35 PM
  #65
08EG's Avatar
08EG
Originally Posted by nismo542
okay i found the pipe i used. it is pex tubing. this is what is written on it..
1/2"id by 5/8"od...H/C Pex Tube. 5ft QB3PS5X. upc is "0 84169 48506 9". i think i got it from ACE Hardware, but it may have been lowes. Anyways, it is a standard size pex tubing that you should be able to find easily.
here is a link to what lowes carries.
http://www.lowes.com/pd_220246-61002...|0%26Ntt%3Dpex
you will see that the pex is more flexable than the stuff in the link you posted, which makes it work well for this application, if it is the size you need.
WOW ... thank you for being specific!!! Even the actual size spec ...
Did you also fill the cavity above the shock with expanding foam or was this enough?
Old Jan 25, 2013 | 06:48 PM
  #66
08EG's Avatar
08EG
Hi everyone,
Would everyone who tried this and it worked post a YES response, just trying to get a tally.
Excited this may have worked for a lot of people. Will try it myself and spread the news.
Old Mar 10, 2013 | 11:20 AM
  #67
labelworkshop75
Attempting this now. Running to Lowes. Will post results
Old Mar 10, 2013 | 04:20 PM
  #68
labelworkshop75
Bought the pvc pipe and the gasket. Just did this mod along with new rear end links. Def can feel a difference cornering. Seems like the clunk is now gone. Thank OP!
Old Mar 10, 2013 | 05:47 PM
  #69
DCJodon's Avatar
DCJodon
My rear coils just started clunking this weekend, I'm going to pull the rears and do this. Thanks for the info OP.
Old Mar 11, 2013 | 05:56 PM
  #70
nismo542's Avatar
nismo542
Originally Posted by 08EG
Hi everyone,
glad to see this is helping a few more people. just to update i haven't had any issues with my original install and it still seems to be holding up fine. i did not do any spray foam for those that have asked.
good luck to all.
Old Mar 24, 2013 | 05:32 PM
  #71
08EG's Avatar
08EG
Finally found the PVC size at Lowes, cut the pieces right in the store 3/16th of an inch, payed for an "hour" at a local shop, and ....
IT WORKED, IT WORKED, IT WORKED !!!!!!!!
Old Aug 8, 2013 | 07:27 AM
  #72
RENFRO's Avatar
RENFRO
I'm running KW V2's, hotchkis sways, and whiteline endlinks. After about 3-4 weeks of driving on all the new parts, I'm having the infamous clunk in the rear as well. Definitely going to try this super inexpensive fix and see if it works. Huge thanks to the OP for getting me looking in the right direction!
Old Aug 8, 2013 | 07:54 AM
  #73
NissanZguy's Avatar
NissanZguy
This is a great write up
I'm saving this one for my files for when I go Coilover and if I hear the same clunking noise
Old Aug 8, 2013 | 08:05 AM
  #74
Waiz's Avatar
Waiz
Originally Posted by Waizzz
I have also pretty much confirmed its my endlinks as well.
I've been wanting to upgrade sways anyway so I will do both.
Recently added Stillen sways and Powergrid endlinks, my problem is now solved and the clunk is gone
Old Aug 8, 2013 | 10:31 AM
  #75
RENFRO's Avatar
RENFRO
How long have you had them on? My clunk didn't show up until about 4 weeks after I installed everything. It's either this spacer fix, or my Whiteline endlinks are binding up
Old Aug 9, 2013 | 07:00 AM
  #76
RENFRO's Avatar
RENFRO
Update: This was, in fact, not my problem. The hole for the lower mount on the rear shock body of the KW's is dead on when it comes to diameter size. However, I did notice my endlinks appeared to be somewhat at a bad angle (whiteline endlinks set to the full soft hole on the hotchkis sway). I moved them to the medium setting. While climbing under the back I also noticed my rear diff bushing has blown. Couldn't see the leak from directly behind the car. It had busted and leaked down the backside of the rear subframe, between the diff cover and the subframe.
Since I moved the endlinks to the medium setting, I haven't heard any clunking. I'm assuming that was part, if not all, of the problem. I'll update again once I get the diff bushings swapped out next weekend.
Old Sep 6, 2013 | 11:35 PM
  #77
dcains's Avatar
dcains
Originally Posted by EddieBingo
What about something like this?
http://www.mcmaster.com/#drill-bushings-and-liners
I've got the same rattling problem... I'm really interested in a permanent fix. They have a piece that's 1/2" inner diameter / 5/8" outer diameter, but 3/8" in length. It could be cut in half to make two spacers, or maybe just used as is...
I just ordered some PTFE lubricated flanged bronze bushings, 8 each of the English and Metric, to see which fit better. Total for the order was just ~$21, so it was worth a try to order both, and from measuring the shocks, it looks like either will likely work. I'm going to change out all 4 shocks, so I'll try the bushings on both the front and rear.
Old Nov 30, 2013 | 04:35 PM
  #78
guitman32's Avatar
guitman32
Fix worked for me, only mine was being caused by a stripped lower shock nut (the one welded to the shock body) which prevented me from being able to torque the bolt down to #74-88. Either way I noticed the hole on the opposite side of the lower shock fork was oblong (~0.5mm oval), which would indicate abnormal wear. The bolt is 11.9mm (12mm bolt), the hole on my shocks measured 14.6mm.
A fresh nut on the one side, combined with a washer on the new bolt, with a bushing added as described by the OP (I used 1/2 rubber hose) eliminated my suspension clunk.
I would be interested to hear if just a washer and a torque to maybe 90ft/lbs would fix the issue without the need for a DIY bushing.
Thanks OP.
350Z_Al
Oct 29, 2020 07:44 PM
