Brake light HELP!
Old Mar 2, 2010 | 05:43 AM
350zgurl's Avatar
350zgurl
Default Brake light HELP!
hello i got a 05 missan 350z track and my brakelight, VDC, and slip light are all on and wont turn off, any suggestions on how to fix or what is wrong?
Old Mar 2, 2010 | 07:58 AM
chromesilverz's Avatar
chromesilverz
Are you losing power? Is it having a hard time starting?
Did you pull a code?
The lights coming on could mean a lot of things. Will need other symptoms and warnings to diagnoze.
Old Mar 2, 2010 | 09:19 AM
DavesZ#3's Avatar
DavesZ#3
Check brake fluid level. Check brake pads.
If those are okay, then you have a real problem - probable with the ABC module.
Old Mar 3, 2010 | 10:07 PM
350zgurl's Avatar
350zgurl
np it has no other problems but when its warm outside like 30 or so the lights turn off its only when its cold mainly
Old Mar 4, 2010 | 10:44 AM
chromesilverz
You probably need new brake pads.
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
