Problems starting
Old Mar 7, 2010 | 06:35 PM
solidfish's Avatar
solidfish
Default Problems starting
I have a 2005 enth. with about 35k miles. The past few weeks, I've had a few times where the car would not start on the first turn. There are no CEL, no smells, no irregular sounds. It would take 3 or 4 tries and then it would start. Once it starts, runs/idles fine, like new.
My first guess was a weakened battery. Its still OEM battery so its about time to be replaced. But the voltage meter is showing 12.5v (not running), which I believe is normal.
It doesnt happen enough to properly diagnose yet, but any thoughts on some other common problems I could check for?
Thanks
Old Mar 7, 2010 | 07:38 PM
Battery has been in service for about 60 months?
Low temperatures in San Jose have been?
Old Mar 7, 2010 | 07:59 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
try another key
Old Mar 8, 2010 | 04:31 AM
makopolo's Avatar
makopolo
Thanks
I would take the battery to get tested. Although it has the correct voltage they need to put it under load to see if it can still deliver enough current to crank up the car.
Low temperatures can also reduce battery capacity but it should still start on the first try.
Old Mar 8, 2010 | 08:36 AM
solidfish's Avatar
solidfish
I had the same problem this morning again. Seems to be getting more frequent.
You're right about the crank voltage, I forgot to consider that. I'll drop by autozone during lunch to get it tested. I'm guessing thats exatly the problem.
thanks for the responses
Old Mar 8, 2010 | 09:26 AM
chromesilverz's Avatar
chromesilverz
A battery is not that expensive and you are probably due for a new battery anyways.
Around the 5 year mark is when most of the Z batteries have been kicking the bucket.
Old Mar 8, 2010 | 10:04 AM
cheshirecat79's Avatar
cheshirecat79
does the engine actually turn over?
Old Mar 8, 2010 | 10:23 AM
JasonZ-YA's Avatar
JasonZ-YA
CCA - COLD CRANKING AMPS - voltage is crap! its all about where the kick comes from and thats current in amps buddy......
battery is a gonner......
the more you try and mess with it, the more you strain the alternator and starter, i hope you get a new battery before those two are prematurely killed due to the strain you put on them from trying to run them with a bad battery....
Seen it happen......
-J
Old Mar 8, 2010 | 01:32 PM
solidfish's Avatar
solidfish
update -
Got it tested and indeed it seems to be a battery problem. It was only putting out 4 cranking volts, which I believe is half of what is normal. Searching around for the best replacement now.
Thanks!
Old Mar 9, 2010 | 05:07 AM
makopolo's Avatar
makopolo
update -
Thanks!
Amazing that that thing would even attempt to crank the engine, Thats not even enough current to run lights. Good thing you didnt toast your alternator.
Old Mar 9, 2010 | 09:47 AM
solidfish's Avatar
solidfish
Actually, I believe the surface volts is what actually powers the other electronics. It read 12.4 surface volts but only 4.? cranking volts. So my radio, lights, etc were functioning fine. It just didnt have the crank volts to crank the engine. I'm not good with batteries but I guess thats how it works.
Old Mar 9, 2010 | 11:15 AM
chromesilverz
Duralast Gold from autozone. Lots of cranking amps and at least 5 additional HPs .
Old Mar 9, 2010 | 12:41 PM
saywat?'s Avatar
saywat?
this happned to my bros car. the oem batts have some water in them that needs to be check to make sure its full or something. his batt was reading correct voltage but the water was low and had a damaged cel or something. he got a new bat and all is good
Old Mar 9, 2010 | 01:51 PM
solidfish's Avatar
solidfish
+5hp? I dont think thats possible unless youre running a hybrid
Uriyo_
Sep 8, 2021 08:46 AM
