Need Help On Choosing Oils
Old Mar 21, 2010 | 08:29 AM
leeys90's Avatar
leeys90
Default Need Help On Choosing Oils
What oils are you guys normally used for your Z?
For engine oil, I choose Motul 300V Power Racing 5w30. But I am not sure about the manual transmission gear oil and differential gear oil. Based on the Nissan owner manual, manual transmission has to use GL4 75w90 and differential has to use GL5 80w90.
I need you guys to help me on choosing the oils for both manual transmission gear and differential gear.
Old Mar 21, 2010 | 08:45 AM
DavesZ#3's Avatar
DavesZ#3
For both the diff and trans, your best bet is to go with a synthetic like Royal Purple or Redline.
This thread has a lot of info on both...
https://my350z.com/forum/engine-driv...ssion-oil.html
Old Mar 21, 2010 | 08:53 AM
leeys90's Avatar
leeys90
https://my350z.com/forum/engine-drive...ssion-oil.html
Thanks for your information.
Old Mar 21, 2010 | 08:43 PM
FinlyZd's Avatar
FinlyZd
I would not use a racing oil for street use. Any over counter synthetic like mobil,penzoilplatinum, or edge will work just fine and cheaper. Redline does make some good oil but there expensive I only use them since I get a discount and change it every 7k.
For diff and trans.
Use mtl fluid from redline 75w90
And use there gear oil also
It what I've been using and changing every 30k
Old Mar 21, 2010 | 09:18 PM
JoEdaGiGGoLo's Avatar
JoEdaGiGGoLo
I thought Royal Purple was bad to use on street use?
Look in Walmart - Mobile 1 Synthetic is only $21.50??
BTW - Is there any advantage of using the Mobile 0W-40? I think that is what it is? It says it's better than 5W-30 etc etc...but I wonder if its safe to use on our cars?
Old Mar 22, 2010 | 03:12 AM
DavesZ#3's Avatar
DavesZ#3
Actually, save your money and use a high quality dino oil in the engine. Changing it every 3-4K miles is the best thing for your engine in the long run.
Old Mar 23, 2010 | 01:16 PM
Bevo's Avatar
Bevo
I use Mobil 1 5w-30 engine oil
Nissan MTF 75w-85
Nissan synthetic differential oil 75w-90
Old Mar 29, 2010 | 07:10 PM
solar_n_orange's Avatar
solar_n_orange
Oil: Royal Purple 10w-30
Trans: Redline Mt-90
Diff: Redline 75w90
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Tochigi_236
Sep 27, 2015 03:40 PM
