How to Replace Front Parking light on 2003Z
Old Mar 30, 2010 | 03:57 PM
Z YA LATER 2's Avatar
Z YA LATER 2
Default How to Replace Front Parking light on 2003Z
Do I remove the headlight cover? Is it the two screws at the back of the lens inside the engine compartment? Then pop out from there? I'm affraid of breaking the cover.
Old Mar 30, 2010 | 04:12 PM
ericjackson's Avatar
ericjackson
im pretty sure you go through the wheel well. i think you have to pull back the fender liner and go in from there
do not remove the headlight cover
Old Mar 30, 2010 | 04:16 PM
ericjackson
https://my350z.com/forum/body-interi...ng-lights.html
here, scroll down just a bit
Old Mar 31, 2010 | 11:51 AM
Z YA LATER 2
I can see replacing the headlight thru the wheel well but the parking lightbulbs plug in from the front. I can't see doing it without taking off the light cover. I wasn't able to find an answer with your link but I appreciate your help.
Old Mar 31, 2010 | 11:54 AM
KornerCarver's Avatar
KornerCarver
You can access the parking light by going through the wheel well. I just did it last week and it was fairly easy. Just take out the screws along the edge of the fender liner and two or three snap rivets. The liner pulls out and your lights are exposed. Just twist the parking light socket and pull toward you. Replace the light and reverse the process.
Old Apr 3, 2010 | 01:09 PM
ericjackson
i got your PM, i hope you found the answer. if you look at the link again and go down to post 12, they are replacing the parking lights..
etkms
Jun 19, 2022 06:30 PM
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
seagrasser
Oct 11, 2015 03:27 PM
