SRS Light
Old Apr 11, 2010 | 06:43 AM
jp4z's Avatar
jp4z
Unhappy SRS Light
I had my driver seat re-upholstered. Now the Supplemental Airbag Light is constantly blinking. I took the seat out, checked all connections, un/reconnected all but can't find a problem. Is there a reset somewhere?
thanks
Old Apr 11, 2010 | 07:14 AM
ocdz's Avatar
ocdz
google?
1. Turn ignition switch from OFF to ON.
2. Air Bag warning lamp is on for 7 seconds and turns off, the turn ignition switch OFF within 1 second after the lamp turn off.
3. After ignition switch is turned OFF, wait for more than 3 seconds.
4. Repeat steps 1 to 3 two more times. (Perform 3 times in total.)
5. Turn Ignition switch ON.
6. The SRS lamp has been reset it.
Old Apr 11, 2010 | 07:32 AM
jp4z's Avatar
jp4z
thanks for the reply ryamartin. The problem is that the light never turns off; it continually blinks from the time the ignition is turned on.
Old Apr 11, 2010 | 07:37 AM
marques1's Avatar
marques1
i see your problem then do this. I believe once you turn on your ignition the light will hold steady just for a second before blinking you have to time it correctly. before it blinks quickly turn the ignition to the off position. Get in your car and give it a try its one of those things you have to try it to get what im saying. So, basically when the light turns off to try to blink again you have to turn the ignition switch off before it reappears. I hope you get what im saying it's kind of confusing to explain this over the internet. repeat this as said above and your srs light should go off.
Old Apr 11, 2010 | 07:38 AM
jp4z's Avatar
jp4z
I take that back. I tried it and it did go out.
thanks again for the info ryamartin
Old May 9, 2010 | 12:20 AM
fla350tt's Avatar
fla350tt
Default The answer is usaully on this forum
I was wondering why that stupid light started blinking after I did the stereo install. I am glad I woke up at 3 o'clock now, just stroll n through the forums. Yeah its off
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
