5th gear grinding
Old May 24, 2010 | 04:57 PM
zJames's Avatar
zJames
Default 5th gear grinding
My fifth gear has been grinding lately. It does it about 1 out of every 3 shifts. It happens when the car is warmed up or cold, low revs and high revs, and yes the clutch was all the way.
Any suggestions as to what it could be?
Thanks
Old May 24, 2010 | 05:00 PM
Nexx's Avatar
Nexx
its a very common problem. mine does it pretty much when i try shifting hard/quickly into 5th. its your syncro going out. time for a new tranny if you really want to get rid of the problem. you could also try new fluids.
Old May 24, 2010 | 05:03 PM
Viggy75's Avatar
Viggy75
that happens with my 3rd gear when i shift over 7grand when im racing and shifting hard every other gear is perfectly smooth.... how to fix syncros? how to drain tranny fluid and what should i try?
Old May 24, 2010 | 05:06 PM
zJames's Avatar
zJames
yeah im putting new fluids in this weekend. ill see if that helps. i didnt know if it had anything to do with the clutch or not. but ill look into the syncro issue. thanks.
Viggy75's Avatar
Viggy75
anddddd is it covered under warranty if i do need a new tranny?!
Old May 24, 2010 | 05:07 PM
zJames's Avatar
zJames
im with ya viggy
Old May 24, 2010 | 05:08 PM
zJames's Avatar
zJames
and yea shud i get tranny fluid from the dealer or is there a good brand out there?
Old May 24, 2010 | 05:09 PM
Nexx's Avatar
Nexx
you can replace your syncro but most people end up getting a cd009 transmission, which is suppose to be a better shifting version. you can find a good deal on one for less than a $1000 used. as for draining the tranny fluid, its pretty easy if you are decent a working on cars. i believe there is a DIY in the DIY section, but honestly, changing fluids rarely fix grinding problems.
Old May 24, 2010 | 05:16 PM
zJames's Avatar
zJames
fml. alright.
Old May 24, 2010 | 05:38 PM
dirtbikr's Avatar
dirtbikr
Just go from 4th to 6th
Old May 24, 2010 | 07:31 PM
Probably need a new transmission. A rebuilt one will cost less.
Old May 24, 2010 | 10:45 PM
Mike@Blackline's Avatar
Mike@Blackline
its the only solution. replacing any parts does not fix it. knew a local guy who replaced every single component of his tranny (he was rich so he just dropped it off at a shop over and over) and after about a year every part of the tranny was brand new and he still had it
Old May 25, 2010 | 01:41 PM
Bevo's Avatar
Bevo
Nissan powertrain warranty is 5 yrs/ 60k miles.
Old May 25, 2010 | 01:51 PM
pntfrk69's Avatar
pntfrk69
fuuuu.... i just hit 61,000 fml
Old May 25, 2010 | 02:59 PM
ms6to350z's Avatar
ms6to350z
my 5th gear was grinding also and after a little hassel from service they ordered me a new transmission. should be in thursday or friday. 18,900 miles and inservice date of july 2007.
Old May 25, 2010 | 03:03 PM
Nexx's Avatar
Nexx
damn that sucks!!!
Old May 25, 2010 | 04:19 PM
zJames's Avatar
zJames
Angry
yea tell me how that goes. and have a 03 with 28k so the powertrain is out of warranty to.
Old May 25, 2010 | 05:27 PM
ms6to350z's Avatar
ms6to350z
most likely the synchros. since you're out of warranty if you really want it fixed i'd get the parts from them and have a cheaper transmission shop do it, or nissan will prolly charge you an arm and a leg.
Old May 25, 2010 | 06:40 PM
Zero260's Avatar
Zero260
I have the 3rd gear grind over 5k. I just found a deal on a cd009. getting it next week.
I tried talking the dealer into doing it under warranty, 33,000 miles but a 2003. they wouldn't budge.
Old May 25, 2010 | 06:46 PM
Viggy75's Avatar
Viggy75
haha mines an 08 with 34k so i can get a whole new tranny for free?!
