AC Pump issue. Suggestions?
Old Jun 30, 2010 | 06:49 AM
Romanteni's Avatar
Romanteni
Default AC Pump issue. Suggestions?
Ok, so after searching the forum, its kind of hard to do a sear for "AC" lol... I can't really find something like this, so if you can, plz help out.
Here's what happens. When I press the AC button inside the cabin - both fans come on, start blowing air, I feel the RPM kick up a notch. Whats not happening- is pump turning on. So basically it still blows warm air.
If I connect +/- to battery and then connect the + directly to the pump wire, it does come on, and starts blowing cold air for as long as I'm holding it there.
Now what I'm wondering, is there a separate fuse or something for the pump? I checked all the connections (i think) and it seems that everything is connected... Any suggestions here on maybe a "common" issue like this one?
Help is appreciated, thank you.
Old Jun 30, 2010 | 08:27 AM
winchman's Avatar
winchman
Section ATC of the service manual has all the info you should need to find and fix the problem.
Old Jun 30, 2010 | 11:30 AM
Romanteni's Avatar
Romanteni
Yes I've looked at all diagrams etc etc, I'm at work right now, so all I can do before I get home and jack it up- is research. Thats why I'm doing all the research now, so when I get home, I only have about 4 hours, I can jack it up, and I'll know which places to look.
I'd really appreciate suggestions, or people that had similar problems (even if its something I already know). I know it can be pressure sensor, I know where it is, I know it can be the relay etc etc etc, but maybe someone had a similar problem and it was something else. Please post on here, I have to go on a roadtrip tomorrow for work, and it would REALLLY suck if I don't find it tonight.
Last resort, I'll end up running a + from wire harness to the compressor, and just leave ac on at all times or something...
350z82
Oct 1, 2015 06:25 PM
