Bank 2 oxygen sensor replaced now engine code same?
Old Jul 5, 2010 | 08:08 AM
dudegetalife's Avatar
dudegetalife
Default Bank 2 oxygen sensor replaced now engine code same?
Replaced the oxygen sensor hooked it up correctly did battery thingy to reset car and 100 miles later check engine light came on with same code... anything else need to be changed or could be the cause of it?
Old Jul 5, 2010 | 08:32 AM
cdoxp800's Avatar
cdoxp800
Whats the code?
Old Jul 5, 2010 | 03:32 PM
diablox1's Avatar
diablox1
do u have test pipes or hfc? if so, lol, and the code will keep returning.
Old Jul 5, 2010 | 04:01 PM
0jiggy0's Avatar
0jiggy0
Dudegetamoreinfo
Old Jul 5, 2010 | 04:22 PM
huyrua's Avatar
huyrua
Vague problem gets vague answer.
Old Jul 5, 2010 | 04:40 PM
dudegetalife
no exhaust mods whatsoever.
can't remember code but now the check engine light is back on codes are p0420 and 0430 which are both side catalysts.
I do not believe they are both bad at the same time something else must be causing the engine light.
gas mileage is averaging 16mpg when before my check engine light problem it was averaging 19mpg in the city.
what else could cause something like this.
I've run emission cleaners before and it keeps the light off for about 2-3 weeks and then it comes back on.
Old Jul 5, 2010 | 04:46 PM
cdoxp800's Avatar
cdoxp800
p0420 - Catalyst system efficiency below threshold Bank 1
http://www.nissanhelp.com/diy/obd_codes/p0420.htm
p0430 - Catalyst system efficiency below threshold Bank 2
http://www.nissanhelp.com/diy/obd_codes/p0430.htm
I am going to say you have bad Cat's. You may want to drop them and inspect them. They may be coming apart
Old Jul 5, 2010 | 04:51 PM
dudegetalife
yes i know but something is causing it besides the catalytic converters
Old Jul 5, 2010 | 10:37 PM
bikinilust's Avatar
bikinilust
Possible cause:
* Three way catalyst (Manifold)
* Exhaust tube
* Intake air leaks
* Fuel injectors may be faulty
* Fuel injector leaks
* Spark plugs may be faulty
* Improper ignition timing
* Engine Control Module (ECM) program
Old Jul 6, 2010 | 07:06 AM
dudegetalife
would you notice if the fuel injectors were bad or if the air intake was leaking?
Old Jul 6, 2010 | 07:50 AM
marco_mendoza's Avatar
marco_mendoza
The cats have an 8 year 80,000 mile warranty hopefully you haven't passed that mileage.
Old Jul 6, 2010 | 08:23 AM
Zazz93's Avatar
Zazz93
What have you recently updated/mod'ed?
Old Jul 6, 2010 | 08:34 AM
BoomerZ33's Avatar
BoomerZ33
subscribed for solution to problem
My CEL is on as well due to failed sensors in both banks
Old Jul 6, 2010 | 10:01 AM
dudegetalife
past that mileage currently at 117k
recently changed oxygen sensor cuz code kept coming up oxygen sensor before that was shocks and before that was control arms... that's as far as i can remember back. spark plugs were changed at 100k so was pcv valve and valve cover itself.
Old Jul 6, 2010 | 10:13 AM
Zazz93's Avatar
Zazz93
I'm guessing a broken cat, but check for air leaks, bent exhaust pipe and bad plugs. Possibly even bad packs. The fact its throwing both banks codes bother me. If it were throwing one, a bad cat would make more sense but the odds that both cats went out at or around the same time is odd. That makes me think something may be off alittle further backward up the sytem, such as with the fuel system but that should have thrown a mixture code as well. Also check to see if you bottomed out on the cats and possible broke them that way. Generally you can hear a rattle if the cats are bad, plus you'll generally feel a power loss.
Old Jul 6, 2010 | 10:50 AM
dudegetalife
no power loss just up with gas mileage i did hook it up to a live data code reader in may and it showed that both the upstream o2 sensors were running rich but before changing out my right side one last week i pulled the code and it was just showing it for that one.
Old Jul 6, 2010 | 10:53 AM
0jiggy0's Avatar
0jiggy0
Why is it impossible to believe you need cats @ almost 120k? If both sensors are switching back and forth and almost mirroring eachother you have bad cats. The rear O2's should hover around .5V on a perfect running car.
Old Jul 6, 2010 | 11:49 AM
bikinilust's Avatar
bikinilust
Ive seen someone on craigslist selling their cats for under $200
Old Jul 6, 2010 | 11:54 AM
bikinilust's Avatar
bikinilust
if there is a leak, spraying carb choke cleaner or brake cleaner all around the plenum flange will cause the rpm to rise
not sure how to check injectors
Old Jul 6, 2010 | 07:33 PM
dudegetalife
because what if its not the cats
i'm trying to go by what costs the least and if at the very end i need to buy cats i'll buy em but if its not them and i spent $200 + install i will feel
liqalu04
Jan 2, 2022 12:58 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Mattg350z
Oct 2, 2015 06:51 AM
samansharif
Sep 25, 2015 12:31 PM
