How much brake fluid for bleeding brakes and clutch
Old Jul 7, 2010 | 06:49 AM
spacemn_spiff's Avatar
spacemn_spiff
Default How much brake fluid for bleeding brakes and clutch
Does anyone know the quantity needed for bleeding both clutch and brakes? I looked all around and in the service manual and didnt find anything specific.
I was going to buy 2 liters of ATE brake fluid. I did bleed brakes once about 4 years ago, I think it needed 1 liter or slightly more for the brakes. So I am thinking 2 liters should be good enough for both. Anyone know for sure?
Old Jul 7, 2010 | 09:21 AM
DavesZ#3's Avatar
DavesZ#3
There's no set amount. It all depends on how much you let run through the system at each wheel . I probably overdo it at around 2 quarts. The clutch doesn't require much at all.
Old Jul 7, 2010 | 10:22 AM
spacemn_spiff
Thanks Dave for the quick response.
2 liters is slightly more than 2 quarts. I am doing a complete flush for the brakes (I have brembos which may require slightly more fluid.) I have ATE blue now and I will replace it with ATE Gold. Is 2 liters all that I need to order for both brake and clutch then?
Old Jul 7, 2010 | 01:49 PM
DavesZ#3's Avatar
DavesZ#3
Yes. I have Brembos too. The clutch only holds a few ounces of fluid so it almost doesn't count.
lapham3
Oct 7, 2022 03:15 PM
samansharif
Sep 25, 2015 12:31 PM
