Please help identify this part
Old Sep 13, 2010 | 01:01 PM
Tullio's Avatar
Tullio
Question Please help identify this part
Sorry if this is in the wrong sub-forum. Since I don't know what this part is, I have no clue what section it would go in.
I have been looking everywhere and I cannot seem to identify this part or what it does.
I noticed it when I had the drivers side inner fender taken off while accessing the back of the headlight housing.
It's bolted in with a bushing of some sort that allows it to swing from side to side and spring back.
Anybody?
Old Sep 13, 2010 | 02:11 PM
DavesZ#3's Avatar
DavesZ#3
Is it on both sides are of the car or just the driver's side?
Old Sep 13, 2010 | 02:13 PM
Tullio's Avatar
Tullio
Heh, that's the first thing I checked!
Driver's side only...
Old Sep 13, 2010 | 02:14 PM
turbocad6's Avatar
turbocad6
looks to be a vibration dampener..., they use stuff like this on exhausts & tranny cross members sometimes too, just an isolated weight really... kinda does the same thing as if something was vibrating a bit then you hold it with your hand & it stops vibrating...
Old Sep 13, 2010 | 02:26 PM
DavesZ#3's Avatar
DavesZ#3
I wonder if that is roadster specific. I don't recall seeing anything like that under my coupe.
Old Sep 13, 2010 | 02:27 PM
Tullio's Avatar
Tullio
Perhaps. Maybe that's why i am having such a hard time figuring it out.
Old Sep 13, 2010 | 03:46 PM
DavesZ#3's Avatar
DavesZ#3
What is that big black lump made of? From the picture, it looks like styrofoam.
Old Sep 13, 2010 | 04:29 PM
Zazz93's Avatar
Zazz93
The bracket is called a "Stabilizer Reinforcment Bracket" per the FSM. But I couldn't find the pivot. The bracket looks to stabilize the welded section of the front member.
Old Sep 13, 2010 | 04:44 PM
Tullio's Avatar
Tullio
It is definitely solid metal. Looks cast. It's very heavy from the feel of it.
I was looking through the FSM too and originally thought I found it under Stabilizer Reinforcement Bracket but then saw that same name refer to the sway bar bracket...
Old Sep 13, 2010 | 04:47 PM
DavesZ#3's Avatar
DavesZ#3
Stabilizer reinforcement bracket sounds like the piece that holds the front sway bar which is seen to the right of the unknown object in his pic. I searched the FSM for that term and don't get a hit. There's nothing on the courtesy parts site with that description either.
Old Sep 13, 2010 | 08:05 PM
Zazz93's Avatar
Zazz93
Check in the Body Repair section of the BODY, LOCK & SECURITY SYSTEM on page 264. Looks like the mount to the pivot.
Old Sep 13, 2010 | 10:00 PM
turbocad6's Avatar
turbocad6
if it's just a heavy weight on a rubber centered mount, like a motor mount type mount but with nothing actually connected to it then it's def a vibration dampener
Old Sep 14, 2010 | 06:47 AM
Tullio's Avatar
Tullio
I looked through the body section and I don't see anything that looks like the bracket or the weight thing in the picture.
Could very well be a vibration dampener but we should be able to identify it in a diagram somewhere and find out what exactly it is dampening and why (apparently) only in a roadster.
If all else fails I think I will swing by the Nissan dealer with a picture. But that doesn't mean that they will know either.
Old Sep 15, 2010 | 06:27 AM
Tullio's Avatar
Tullio
Bump, anybody else have a idea?
Old Sep 15, 2010 | 11:05 AM
Zazz93's Avatar
Zazz93
My suggestion is to search out some of these track savvy vendors, like Forged or Performance Nissan and ask. I would imagine they would remove dead weight if it is really for harmonics.
Old Sep 15, 2010 | 12:48 PM
DavesZ#3's Avatar
DavesZ#3
Can you post the page from your FSM that shows that part?
Old Sep 15, 2010 | 01:02 PM
Tullio's Avatar
Tullio
I am not sure which diagram Zazz93 is talking about. The body section in my FSM only goes up to 260. Maybe I have a older version. But the manual says on page 2 that it is for the 2004 which is what I have.
I put up my BL section here
On page 247 of the PDF I posted, it shows the "Stabilizer Reinforcement Bracket" which I believe is what he is referring to but I don't think that is the same part as the picture I posted.
Old Sep 15, 2010 | 01:14 PM
DavesZ#3's Avatar
DavesZ#3
Try page 258 in the 2004 manual. It's a bracket, it doesn't look like the part in your picture.
Old Sep 15, 2010 | 01:16 PM
Zazz93's Avatar
Zazz93
I originally thought this was the part it pivoted on, but I'm not so sure any longer. (See first item circled on the lower left)
Old Sep 15, 2010 | 01:20 PM
Tullio's Avatar
Tullio
The page 258 is title "Rear side member"
This bracket is in the front.
Yea, I am with you.
