engine knock when starting
Old Sep 25, 2010 | 05:26 PM
Rich M's Avatar
Rich M
Default engine knock when starting
Sometimes when I start my z I hear a single knock just before it starts. Any ideas? She runs perfect, just seems weird.
Old Sep 25, 2010 | 10:19 PM
winchman's Avatar
winchman
Video with sound??
Old Sep 26, 2010 | 09:34 AM
silvertouringz's Avatar
silvertouringz
i hear a knock too when starting!! same issue here
Old Sep 26, 2010 | 10:24 AM
winchman's Avatar
winchman
"...just before it starts." Just before the starter begins to turn the engine, or just before the engine begins running?
Probably need more clues to get a good answer. Mileage? DE or HR? Mods? Where the noise seems to be coming from? Engine cold or hot?
Old Sep 26, 2010 | 10:38 AM
raycs7's Avatar
raycs7
I have a rattle just as it starts.
I suspect the timing chain tensioner.
This only happens on initial startup after extended shutdown period.
Old Sep 26, 2010 | 01:31 PM
silvertouringz
before the engine starts running...04.5 DE...68,800 miles...cold...
Old Sep 27, 2010 | 12:36 AM
dirtbikr's Avatar
dirtbikr
You are absolutely right with the chain tensioner. A lot of DEs in the maxima community have this too. Some of them have installed an oil primer that gets oil pressure up to about 30psi for 10 seconds or so max before they start the car, which makes the chain tensioner tighten up and makes the knock go away.
OP not saying this is or isn't your problem, but it's a known DE thing when the chain starts getting looser.
Old Sep 27, 2010 | 08:36 AM
Zazz93's Avatar
Zazz93
Tough to diagnose, so many possibilities. What is really wierd is the single knock description though. Anything that I can think of would knock or slap for a few seconds at a minimum, such as pistons.
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
