clutch problem. especialy while drifting
Old Oct 11, 2010 | 07:13 AM
AngelsVQ's Avatar
AngelsVQ
Question clutch problem. especialy while drifting
so i bought a 2006 base 350z with 47k miles last month, at the time the clutch felt weird and unpredictable. i assumed i just needed to get used to it. and i did in a couple days. the 2 weeks later i noticed that the clutch pedal would not come up all the way. i had to pull it up about 1/2 to an inch up. but sometimes it would spring back like normal but just for a couple minutes, then it would go back to not coming up all the way. this has made the engagement unpredictable too. i have bled the clutch 3 times now and its not helping i also checked the slave cylinder its not leaking. do i need to replace the clutch? anything i can try before i do that?
another note: ive launched and driven it hard doping the clutch and it does not slip at all! grabs very strong. so that's why im confused.
BUT ive had 3 drift sessions now, the last one i just lost the drift because the power did not get to the wheels, the motor kept reving but nothing made it to wheels. tried again and same thing. then literally 20 seconds after, i tried a hard strait away and it garbed very strong.
ive owned hondas since i was 16 (im 21 now) and im very knowledgeable on them. but this z has me confused.
do i need a new clutch?
Old Oct 11, 2010 | 07:28 AM
AcidJake75's Avatar
AcidJake75
Living in 350Z
Question
drifting on an open diff? did the 06 base come with VLSD? I didnt think they did.. I didnt know that ANY base model came with VLSD..
Old Oct 11, 2010 | 07:34 AM
AngelsVQ's Avatar
AngelsVQ
its is open, believe me i can do it ha, i am planning on installing an lsd tho. tho i owned hondas all my friends had 240's, thts how i picked up drifting. and some of those where one leggers too
Old Oct 11, 2010 | 07:35 AM
AngelsVQ's Avatar
AngelsVQ
and i never said i had vlsd sir
Old Oct 11, 2010 | 08:13 AM
Wu-Watt's Avatar
Wu-Watt
I have an 06' with the same issue. I have replaced the clutch line(SS), master, slave, fluid, I have bled the line, wrapped the line with heat wrap, bled the slave....
It only happens with high rpm shifts. The pedal will drop, and after a couple shifts it's back to normal. Clutch holds fine too, I've done burnouts and launches to test it out and all good. I have an aftermarket clutch/fly, (exedy stg 1/fidanza) with like 20k on it so I'm really confused. I might replace the clutch next year again...
Old Oct 11, 2010 | 08:24 AM
AngelsVQ's Avatar
AngelsVQ
its frustrating because it happens so often. makes the drive un-enjoyable . did you have that issue before you replaced the clutch?
i dont want to buy a new one and continue having the same problem...
Old Oct 11, 2010 | 08:35 AM
Wu-Watt's Avatar
Wu-Watt
Ya it blows.. I only got to track the car 1 time this year because of it.
So in July or so of 09' I had the clutch/fly upgraded. (not worn out)
I did not have the issue in 09'. Then this year I started getting the sinking pedal in hot weather, regular driving, and the pedal would just sink.
So I replaced the line to a SS line, and put in some Motul. The pedal stopped dropping in hot weather, but when I went to the track the problem came back. So I bled the line like 3 times, replaced the master, slave, wrapped the line, bled the slave... Adjusted the clutch pedal. And it wont go away. I also tried reverse bleeding the clutch.
I took the car to SG and Sasha said that if I replace the clutch it will probably fix the issue. But the car drives fine all the time unless I rev it up to 6k, so I dont want to replace the clutch!!!
It has to be either air in the line, or a internal clutch issue. I have also heard that Nissan master/slaves suck *****.
Old Oct 12, 2010 | 07:05 AM
Brett@AwesomeZ's Avatar
Brett@AwesomeZ
Vendor - Former Vendor
May want to see if the pedal needs to be adjusted. You can check this out in the clutch section of the FSM.
Old Oct 12, 2010 | 12:51 PM
Wu-Watt's Avatar
Wu-Watt
Ya the pedal was adjusted too by Sasha at SG.. He thinks the clutch needs to be replaced, but it doesnt slip!!!! I'm giving up on it for this year, i'll probably grab a clutch from a member when I can over the winter and see if that fixs it..... I really dont want to spend that kind of money but..
Old Oct 12, 2010 | 05:39 PM
AngelsVQ's Avatar
AngelsVQ
im in he me boat man! its grabs but also theirs signs that it needs to be changed... my pedal is also properly adjusted. like i said ive bled it a few times and ive adjusted it twice now. it sucks cuz ive only had it for a month
ive ordered a the forged ss clutch line and im going to use motule 600... i have a feeling its not going to fix my issue.
Old Oct 13, 2010 | 11:32 AM
Wu-Watt's Avatar
Wu-Watt
I think that will fix your problem.
I'm having some stupid issue because my karma is after me.
liqalu04
Jan 2, 2022 12:58 PM
Uriyo_
Sep 8, 2021 08:46 AM
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
