100K check up, advise please
Old Oct 12, 2010 | 07:03 AM
importpunisher's Avatar
importpunisher
Default 100K check up, advise please
Need help making a list of things to do for a 100k check up.
spark plugs
oil/filter
check P.S, Brake, clutch fluid
Trans and diff fluid
Old Oct 12, 2010 | 07:09 AM
Brett@AwesomeZ's Avatar
Brett@AwesomeZ
Vendor - Former Vendor
-Cooling system flush
-air filter (or cleaning if you have an aftermarket intake)
-cabin filter (really easy to do)
-wouldn't hurt to check the alignment too if you have never had it done.
-drive belts
-thorough inspection
Old Oct 12, 2010 | 07:20 AM
JasonZ-YA's Avatar
JasonZ-YA
For piece of mind you may wanna have a compression test done...
also have you had any bushings replaced???
I would bet that the front transverse link and compression rod bushing are done even if it was a daily driver...I would NOT pay good money on a Alignment unless those bushings were replaced first...no point.... it wont hold...
Front lower control arms - aka transverse link and compression rod:
Review front bushings here:
https://my350z.com/forum/8293650-post23.html
also, check your rear diff bushings for the typical silicone black fluid leak.
Review diff bushings here:
https://my350z.com/forum/8293651-post24.html
Also, check the front lower knuckle ball joint:
Review ball joint here:
https://my350z.com/forum/brakes-and-...ll-joints.html
-J
Old Oct 12, 2010 | 07:28 AM
Brett@AwesomeZ
True that, these cars eat up those front lower control arm bushings. That is part of the thorough inspection the car should get, also tires, check for leaks etc.
edit: and by tires I mean check them out and make sure they aren't wearing irregularly.
Old Oct 12, 2010 | 12:13 PM
DavesZ#3's Avatar
DavesZ#3
Sticky at top of this forum.... https://my350z.com/forum/maintenance...intenance.html
Old Oct 13, 2010 | 11:54 AM
importpunisher
-J
will do and get back to your pm once i start the 100k inspection which will be very soon. i just hit 99k today!!
Jambo016
Sep 16, 2016 01:08 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
