Overheating problem - Need advice
Old Oct 21, 2010 | 12:58 PM
ltruong's Avatar
ltruong
Default Overheating problem - Need advice
Hi guys,
Just a couple days ago, my 2004 starts to overheat. Within 15-20 minutes on freeway/local car temperature gage hovers around 3/4 - 7/8.
Some tests I did:
With A/C on fullblast, only left fan is spinning
When car overheat, both fans spin
Took the car to dealer this morning, they found that the radiator assembly is NOT radiating coolant correctly, lower portion of radiator is cold while upper portion is hot. Recommendation is to replace radiator for $900
Any advice. Thanks
Old Oct 21, 2010 | 01:26 PM
350z006's Avatar
350z006
Buy a good aftermarket radiator (Koyo, $160 oem size, $290 36mm size), then take it to a good shop in the OC (JER, Project Import, Corner 3 Garage) who will charge you way less to install (Probably $200 to $400) than the dealership, and you're all set...or you can install it youself, it's not too bad...
-OR-
It may just be a busted thermostat, since the coolant flows from the theromstat to the lower part of the radiator to the higher part of the radiator, much cheaper to replace the thermostat than replaing the radiator, but I would have one of those shops above diagnose it for you...either way, its cheaper than the rip-off dealer...
Originally Posted by ltruong
Hi guys,
Some tests I did:
Any advice. Thanks
Old Oct 21, 2010 | 02:21 PM
turbotoy's Avatar
turbotoy
Go thermostat before replacing radiator. Radiators should not go bad unless it is damaged or full of corrosion (only running water).
Old Oct 21, 2010 | 02:26 PM
Agree with turbotoy. This is not a radiator problem. The radiator stores but does not move water:
a. Check the thermostat. Does it open and close?
b. The water pump is operating properly?
Old Oct 21, 2010 | 02:29 PM
ImWeeZzel's Avatar
ImWeeZzel
try to bleed the air (if any) out of the system before you go out dumping money on a radiator. If that doesnt work, try replacing the thermostat. If worst comes to worst change the radiator. On a side note, check your oil while your at it...
Old Oct 21, 2010 | 06:00 PM
AJCaron12's Avatar
AJCaron12
Try the thermostat first, cheapest easiest thing to do.
Old Oct 22, 2010 | 07:25 AM
ltruong's Avatar
ltruong
"Burp" the cooling system last nite and car still overheat this morning on my way to work. Oil level is good. Will check the thermostat and waterpump as advised.
Thanks guys
Old Oct 22, 2010 | 12:22 PM
ltruong's Avatar
ltruong
You guys are awesome!!!
Had the thermostat replaced today and the car no longer overheat...sweet
Old Oct 22, 2010 | 08:49 PM
350z006's Avatar
350z006
Cool...let us know which rip-off dealership recommended you replace the whole cooling system so us Socal guys can keep away from that place...
Old Oct 25, 2010 | 09:13 AM
ltruong's Avatar
ltruong
Its the Nissan dealership here in Cerritos Auto Square. They, however, didn't charge me any diagnostic fee or pressure me for repair when I declined.
Old Nov 13, 2010 | 11:10 PM
Token_Z33's Avatar
Token_Z33
Any one know were i could find a DIY on replacing the thermostat?, im having similar issues and have already bought a new thermostat cause i was told that it was the first logical step.
Old Nov 17, 2010 | 11:58 AM
Token_Z33's Avatar
Token_Z33
Anyone?
Old Nov 17, 2010 | 09:20 PM
Black_Sunshine's Avatar
Black_Sunshine
That's where I bought my 2nd Z. They are the biggest f-ing scumbags.
Old Nov 19, 2010 | 01:27 PM
Token_Z33's Avatar
Token_Z33
new thermostat didnt fix my problem..now what?
Old Nov 19, 2010 | 02:16 PM
ImWeeZzel's Avatar
ImWeeZzel
bad heater core? I bought two thermostats because the first replacement (Autozone brand) was just as bad as the one I replaced. The second one was OEM replacement, no problems afterwards.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
