need help
Old Oct 28, 2010 | 07:44 AM
andres benitez's Avatar
andres benitez
Question need help
Hey guys turned on my carthis morning and my vdc,slip,and brake light stay on. Has this happend to any one before? What can I do to fix it thanks in advance.
Old Oct 28, 2010 | 08:04 AM
CCDesigns's Avatar
CCDesigns
its possible that your brake fluid is just low. if that is the case you probably need new brake pads also. is the abs light on?
Old Oct 28, 2010 | 08:12 AM
PerfZ's Avatar
PerfZ
Crank or cam position sensor most likely. SES light on? Need to get the code read - lot's of places do it for free.
Old Oct 28, 2010 | 08:28 AM
Z_HighSpeed's Avatar
Z_HighSpeed
did you drive the car after the light turned on?
sometimes they go off after a mile or two
Old Oct 28, 2010 | 09:14 AM
andres benitez
No just the 3.all the others turn off like there suppose to.
Old Oct 28, 2010 | 09:16 AM
andres benitez
No ses light on just the 3 I mensioned.do I need to get the codes even if the check engine light isn't on?
Old Oct 28, 2010 | 09:20 AM
andres benitez
I thought the same thing but still hasn't come off I've been driving it all morning.its weird because it was fine yesterday.lol
Old Oct 28, 2010 | 09:38 AM
CCDesigns's Avatar
CCDesigns
Did you check your brake fluid yet? If the car is still driving normally its probably just that. There is a sensor in the reservoir that will light up all three lights if it is to low
Old Oct 28, 2010 | 11:39 AM
tylerxfire's Avatar
tylerxfire
check brake fluid and pads..if neither is low or needs replacing then try to disconnect bettery for few hours and see if it comes back on..
Old Oct 28, 2010 | 11:41 AM
andres benitez
Just did it seems alright its at about half of the reservoir and the brake light just turned off.
Old Oct 28, 2010 | 12:09 PM
BoomerZ33's Avatar
BoomerZ33
like what tyler said. try disconnecting the battery. this usually eliminates stubborn lights
Old Oct 28, 2010 | 12:45 PM
andres benitez
Well they came off lol I think I moved something on the resevoir by accident . But thanks for the help guys ill now what to do if those dumb lights stay on again. Thanks again
