when i take off in 1st gear the front in pulls up a lil and whenever the car stets back down while shifting into 2nd there is a loud thud noise. Does any no why or where i could look for possible clues why my car is making this noise ?
about 3 mounths ago i hit a curb and did around 4.5k in damage the main part that was destroyed is the rack and pinion so they replaced it now when this lil hole in the wall put it in they idk how to explain it but put it in wrong so when i had it aligned at a pep boys they said they had to disconnect somthing because they could not algine the car correctly now when i take off in first gear hard there is a hard thud when the car sets back down and some times when i make a sharp turn form a stop the same thud come from under the car does any 1 no a way to fix this or have any input on where to look to fix this plzzzzzz help
The issue may be your car going airborne, do you have a huge wing on it? Nonetheless, your car should not be taking off or setting back down; it's not an airplane.
