rear differ ?
Old Nov 19, 2003 | 05:26 PM
LBSOHK's Avatar
LBSOHK
Default rear differ ?
i hear a loud clicking when driving in first and second gear , my mechanic ( not dealer ) says my rear differ is messed up... what would cause that ? thanks
Old Nov 19, 2003 | 05:52 PM
John's Avatar
John
Probably referring to the differential. But a clicking sound sounds like it's the axles, not the diff. Seems a bit wierd though...
Old Nov 19, 2003 | 06:25 PM
LBSOHK's Avatar
LBSOHK
hmm he said it was differential though ...
Old Nov 21, 2003 | 06:49 PM
Stabber's Avatar
Stabber
probably lose axle bolts. I have the same problem
Get them to tighten them to factory specs
Old Nov 25, 2003 | 02:30 PM
Michael_Torpey's Avatar
Michael_Torpey
i have the same exact problem
rotational clicking sound...
help!!!
Old Nov 25, 2003 | 02:37 PM
Michael_Torpey
help!!!
Old Nov 27, 2003 | 02:59 PM
bhobson333's Avatar
bhobson333
This is a known problem. I had it fixed by the dealer under warranty, it never came back. Do a few searches here, I did one on "rear ticking" and got a few hits, but there are better descriptions to be found. Here is the comment my dealer made on the service invoice:
"checked and found noise seems to be coming from rt. rear axle splines where axle goes through rt. hub. Removed right lower control arm and axle from knuckle cleaned splines and applied heavy grease; reinstalled all, torqued axle nut."
If your dealer is blaming the tire feathering on you, find another dealer or print this and stick it in their face:
Tech Bulletin
Old Nov 27, 2003 | 03:00 PM
bhobson333's Avatar
bhobson333
Tech Bulletin
Old Nov 28, 2003 | 02:58 AM
LBSOHK's Avatar
LBSOHK
Tech Bulletin
thanks a lot for the info , will check with the dealer.... and i got the feathering issue under control , spoke with the service manager & told him i had a loooong talk with NNA..
