My Z died while I was driving and now won't turn on.
Old Dec 9, 2010 | 01:54 PM
  #81
omsin523's Avatar
omsin523
Wondering if he ever got the problem fixed
Old Dec 9, 2010 | 05:28 PM
  #82
Edg_R's Avatar
Edg_R
Nothing yet.
...Stealership tomorrow.
Old Dec 10, 2010 | 05:06 AM
  #83
BoomerZ33's Avatar
BoomerZ33
Originally Posted by midtx350z
Nothing yet.
oh man. your wallet is going to get raped. hey did you ever have a powertrain warranty on your car?
Old Dec 10, 2010 | 12:52 PM
  #84
Edg_R's Avatar
Edg_R
How much is ECU?
No I didn't.
Old Dec 10, 2010 | 03:32 PM
  #85
pntfrk69's Avatar
pntfrk69
i just bought one, 950 new plus another 250 to get it programed for the immobilizer
Old Dec 10, 2010 | 04:17 PM
  #86
Edg_R's Avatar
Edg_R
Blegh...
Stealership called and said that when the tow truck dropped it off, they couldn't find any problems with it (WTF?!1!)...
...Told me to pick it up and take it again next time it breaks. So go by, they drive the car around and park it by the front for me to get in. When I get it it won't turn on. Does the same thing it did before.
...So they said they were going to keep it and they suspect it's the ECU and/or the gas pump.
Old Dec 10, 2010 | 04:23 PM
  #87
omsin523's Avatar
omsin523
So they got the car started and driving? I thought ive read that the car would even turn over, now im confused. Hopefully they find the problem. But man it's beginning to sound expensive.
Old Dec 10, 2010 | 04:27 PM
  #88
Edg_R's Avatar
Edg_R
Wat
No, it wouldn't do anything. I posted a video on the first page. I would turn the key and the lights would come on but nothing happened after that.
Old Dec 10, 2010 | 04:54 PM
  #89
johnrojo's Avatar
johnrojo
I remember I had a similar with my talon tsi. It was sitting outside my house warming up when it shut off and would not turn over. All the lights would work aswell as the stereo. I spent hours trying to figure out what was wrong with it replacing parts and what not. Well it turned out being a busted wire running from the positive battery terminal. Soldered the wire back together, wrapped it up, and the car started just fine.
Old Dec 10, 2010 | 05:37 PM
  #90
omsin523's Avatar
omsin523
Blegh...
You said they drove the car around for you? I thought the car wouldn't even move?
Old Dec 10, 2010 | 05:42 PM
  #91
350zion's Avatar
350zion
Professional
Crank position sensor... Ftw
Old Dec 11, 2010 | 03:36 AM
  #92
raycs7's Avatar
raycs7
You got taken.
New ones do not need reprogramming.
Only used ones or if you change keys to your existing system.
Old Dec 11, 2010 | 04:40 AM
  #93
z2g's Avatar
z2g
^^need reprogramming for the keys regardless new or not. new ECU not programmed with the old keys
Old Dec 11, 2010 | 04:41 AM
  #94
Edg_R's Avatar
Edg_R
That's what I'm saying, it started for them.. It must have been the ride over there by the tow truck.
Old Dec 11, 2010 | 05:28 AM
  #95
midz350's Avatar
midz350
Or maybe your car dislikes you
Old Dec 11, 2010 | 05:29 AM
  #96
Edg_R's Avatar
Edg_R
Strong posibility
Old Dec 11, 2010 | 07:13 AM
  #97
raycs7's Avatar
raycs7
I have a similar issue on one of my 350Z's. I just parked it until I have the time and inclination to look into the issue.
I was only referring to what I browsed in an official Nissan Technical release regarding new ECUs and what a member here said when he did his auto to manual swap with a used ECU.
You may be correct. IDK
Old Dec 11, 2010 | 07:19 AM
  #98
350zion's Avatar
350zion
Professional
The bcm n keys have to match.. The ecu gets its signal from the bcm... No signal no start..
Its in the fsm, and something we are currently dealing with on our s14 project.. I have a Guy that can reprogram the bcm but jus haven't had the time...
If I'm wrong I'm wrong but, we've tried everything else...
I'm definitely interested in the out come..
OP u said u had it towed to the dealer n it started n ran for them? then u picked it up n its dead again?
Old Dec 11, 2010 | 11:33 AM
  #99
Edg_R's Avatar
Edg_R
Yes, they came by and towed it to the dealership. Then when their techs got it, it turned on and they were able to drive it.
Then they called me and told me that they ran tests, and everything seemed ok. They told me to pick it up and let them know when it happened again.
I went by, and they drove it around to the front. He parked it, shut it off and came handed me the keys.
We talked for a few minutes then when I went to go start up the car, it would do the same thing that it was doing back at home.
It just wouldn't turn on, all lights came on but nothing else. It wouldn't crank either.
They said they would keep it and try to figure itout.
Old Dec 11, 2010 | 06:29 PM
  #100
350zion's Avatar
350zion
Professional
I been thinking about the crank shaft position sensor... But I jus thought of something stupid . You have an auto... If the car is in gear the results your getting would be typical... Even if the selector looks like its in park it might not be.. Try putting it in neutral or turn the ignition while running it through all the selections.. If the switch that prevents you from starting the car in gear is faulty the car could be thinking its in gear Wen its not.. Wen the Guy towed the car he had to shift it into neutral to move it... Make sure u push the selector all the way forward... I bet that's the issue.... I hope you followed my rant....lolz lemme kno.....
