350z Annoying Rear Rattle Noise - Fix
Old Dec 17, 2013 | 08:10 PM
dcains's Avatar
dcains
If you assign a number to each of the pieces in your second picture, 1 to 7, from left to right - the KYB kit includes #'s 3, 5, and 6, including the metal tube inside piece #3.
In other words, the top and bottom rubber bushings, the metal tube, and top washer. As mentioned in post #21, you should also replace the gasket between the oval metal mount and the car's body. The ones in my '08 were toast, and Nissan probably sells them. but I fabricated my own out of some old rubber inner tube material I had around.
Old Dec 18, 2013 | 05:34 AM
Rev_Night's Avatar
Rev_Night
awesome man thanks. And i plan on changing the gasket with Valve packing sheet, as described here.
https://my350z.com/forum/maintenance...e-for-4-a.html
Old Dec 18, 2013 | 06:53 AM
thetachi49's Avatar
thetachi49
Thank you all so much for this post. I replaced my rear hatch springs, hatch struts, had taken out my spare, jack assembly and was about to swap out the whole hatch-lock assembly (yes, it's that annoying!!) before finally figuring out it was the rear struts that were making the noise, lol. I purchased the KYB kit, new gaskets from Courtesy, and new washers, as well, just to be safe. I'll post an update next week, and hopefully my ride will be quiet, as new!!!
Old Dec 18, 2013 | 10:24 AM
The Burgh's Avatar
The Burgh
I was in the same boat trying to identify where the noise was coming from. I would have sworn it was the rear hatch or the plastic pieces in the trunk. It's been cold as hell here in Pittsburgh, which is when the noise was most noticeable and still nothing.
Drive Safe!
Old Dec 19, 2013 | 06:03 AM
Rev_Night's Avatar
Rev_Night
http://www.courtesyparts.com/-c-714_715_800_804.html
Which parts in there are you referring to?
Old Dec 20, 2013 | 08:10 AM
The Burgh's Avatar
The Burgh
55338 is the gasket that's not included in the KYB kit. I'm sure you could go to advanced and pick up something similar. You just need something to seal out the elements and to stop metal on metal friction. I used an old beer cuzzi because the stores were all closed when I started. Super easy job, just follow the DIY.
Drive Safe!
Old Dec 21, 2013 | 11:23 AM
Rev_Night's Avatar
Rev_Night
ok so i replaced the bad gasket with a homemade cutout from valve packing, coated everything with white lithium grease spray, and I used the KYB parts (but I couldnt use the 3rd part since it was too big). I am still hearing the squeaking from my back. I did some more research, and people suggested changing the end links, but thats not a certainity.
crap, has anyone had this problem and it wasnt solved by changing the gaskets?
Old Dec 21, 2013 | 11:39 AM
dcains's Avatar
dcains
Could be the endlinks. Disconnect the bottom ends temporarily to see. Could also be the interior plastic pieces. The shocks mounts in my car made more of a clunking sound than a squeak, and the same was true of the endlinks.
Old Dec 21, 2013 | 02:47 PM
Rev_Night's Avatar
Rev_Night
damnit. then what could be causing squeaks from the rear?
edit: i read that for whatever reason, a sign of going bad end links is changing the setting from hard to medium, and then seeing if the squeaks persist. I cant remember what mine is at, but this is a good and FREE way to troubleshoot first.
Old Dec 23, 2013 | 07:29 AM
The Burgh's Avatar
The Burgh
Rev_Night. I had the same problem with the part being too big, couldn't screw the nut on. Then i realized you have to flip the top bushing around so the metal cylinder slides into the bottom, which gives it enough room to screw the nut on. That top bushing could still be your problem. Good luck.
Drive Safe!
Old Feb 8, 2014 | 07:02 AM
drunnels's Avatar
drunnels
Question:
I'm assuming this is more of an irritant than a safety issue, but just how much of a safety issue is this if I decide to drive it a while with the rattle?
Thanks.
Old Feb 10, 2014 | 12:07 PM
RULE-1's Avatar
RULE-1
i removed the dried out orange gasket thing and made one out of heavy Feldpro gasket paper. Also used dielectric grease on the OEM rubber stop and knock on wood, no noise for over a year now (2006 model)
Old Apr 15, 2014 | 09:19 AM
Deteria's Avatar
Deteria
Originally Posted by The Burgh
I just fixed my annoying rear squeak with the KYO SM5482 bushing. The bushing kit is a little bigger than the one that is stock, it's correct though. The only thing i would like to add is the rubber gasket that sits on the top mounting plate of the shock bracket was worn. It looked like a piece of bacon. This rubber gasket is not supplied with the kit. I had to improvise with some rubber foam material that was laying around. It's a good idea to replace the gasket when doing the bushings. Best $35 I've spent in a while.
My car is completely silent now!!!
Drive Safe
I had this issue for so long and it was driving me nuts. Especially when it was cold out, my car would thump on every little bump on the road, and almost felt like exhibiting wheel hop as well. Thanks to AcidJake75, had the bushings swapped out and a "custom" gasket installed Now the Z is silent again
Regarding the bushings (KYB SM5842 Kit), not all the parts could be used on my KW Variant 2. I The parts supplied would be much taller than the OEM when stacked together. We ended up just swapping the top bushing (which looks much larger than stock and had a metal disk already) and the cylinder. Didn't use the oem disk at the very top as that top bushing already had a disk melded in.
Apparently when replacing the bushings, we noticed that one side of my car didn't even have a gasket anymore and the side that had a gasket, it was all dried up and crisp. I think the clunking noise I had was due to the gaskets mostly and probably not the bushings but who knows. Still have slight squeaking on very bumpy roads, but probably will tackle those in a while.
Old May 2, 2014 | 08:37 AM
eczap's Avatar
eczap
Had the same problem, bought the parts, installed as mentioned, used all the parts in the kit. NO NOISE! , THANKS
Old May 27, 2014 | 06:36 PM
CroneOne's Avatar
CroneOne
KYB shock mount kit for the WIN.!
I went through a lot of stages here. Initially I thought it was the hatch so I tried the latch reposition trick, which was great because now my hatch clicks tight. Didn't fix the sound though.
https://my350z.com/forum/body-interi...attle-fix.html
Then I tried the pennies in the hatch springs trick which was great because it fixed the need to press the hatch button twice to open the trunk.
https://my350z.com/forum/maintenance...-easy-fix.html
Then I started reading about the lame OEM shock mounts and it all started making sense. Any noise or knocking travelling from the shock to the body would amplify through the rear. I bought the 2 shock mount kits and installed them fairly easily. Used this as a guide
Now it's as silent as lambs. Oh p.s. I removed that dried out crappy gasket from the top mount and re-made a new one with gasket material as well.
Thanks my350 for the info!
Old Feb 7, 2015 | 12:52 PM
vertigocreative's Avatar
vertigocreative
The KYB kit worked perfectly to silent both sides on my car! Used some rubber sheeting for the "bacon" gasket replacement. Thanks for the great help!
Old Feb 23, 2015 | 05:09 AM
ARRRT's Avatar
ARRRT
went the same way yesterday and it worked perfectly!
the weather is rather cold - it's +5'C outside - and no rattling and clunking at all!!!
I'd like to thank everyone for useful information!
by the way, thats how the OEM gasket looked like:
Old Apr 25, 2015 | 10:27 AM
  #38
killermeter's Avatar
killermeter
Thumbs up 350z Annoying Rear Rattle Noise - Fix
Ok I just bought a 2008 350Z with 46K on it, in excellent shape. When I test drove it, I was on a completely smooth road so no noise, but boy the next morning heading into work as the original poster said " it was like driving around with aluminum cans in the back of the car". So I did a google search for "rattle in the back of 350Z" and was lead to My350Z.com and this thread. Today I put in the KYB SM5482 kit on both sides, simple, took about 2 hours total. Lubed everything with white lithium, made a upper "shock to body" gasket out of Felpro gasket material and the noise is COMPLETELY GONE. $30.00 , cant beat that!!
Old Apr 25, 2015 | 01:49 PM
  #39
BigBlue's Avatar
BigBlue
How about this mounting kit for my '07? The reviews down below on this link it mention this exact issue and it sounds like a good mounting kit.
Amazon.com: KYB  SM5482 Shock Mount kit: Automotive Amazon.com: KYB SM5482 Shock Mount kit: Automotive
Old Apr 27, 2015 | 10:46 PM
  #40
calvinloc's Avatar
calvinloc
Thats the right kit. I fixed my 07 with SM5482 kit on both rear sides, been a year without problems. It's easy to do like others said.
