Cruise Control Has Stopped Working
Old Dec 12, 2010 | 12:55 PM
LastODJedi's Avatar
LastODJedi
§ith Mã§t€®
Default Cruise Control Has Stopped Working
Last night I got into my car after work and got onto the highway. When I got up to 65 mph I turned on my cruise control, light came on, but when I went to set it... nothing happened. I have searched through the threads and found owners with a similar issue, but no resolution. I have already reset the ECU and adjusted the sensor on the clutch this morning and still, nothing. Any help would be greatly appreciated!
I have considered that maybe the pedal switch has died. Does anyone have any idea what one costs as well? I have a '05 Touring, all stock.
Old Dec 12, 2010 | 01:08 PM
350ZTheStandard's Avatar
350ZTheStandard
Bummer, I am in for others who have had this problem & the solution.
Old Dec 12, 2010 | 01:13 PM
LastODJedi's Avatar
LastODJedi
§ith Mã§t€®
I also found a mention about the sensor on the brake pedal, if it's not engaged it will trick the ASCD into thinking you are breaking and will cause it not to work. I checked it as well, and it seems to be fine.
Old Dec 12, 2010 | 02:10 PM
DavesZ#3's Avatar
DavesZ#3
Here's all the things that affect Cruise (ASCD)
Old Dec 12, 2010 | 10:13 PM
R350Zz33's Avatar
R350Zz33
just get a brick and rest it on the gas problem solved
Old Dec 13, 2010 | 08:54 AM
jmahad01's Avatar
jmahad01
Do you have an alarm installed?
Old Dec 13, 2010 | 09:32 AM
goose30's Avatar
goose30
Default Ha Ha
That's funny!
Old Dec 13, 2010 | 09:58 AM
cheshirecat79's Avatar
cheshirecat79
aftermarket led tails will also cause this to happen
Old Dec 14, 2010 | 11:02 AM
LastODJedi's Avatar
LastODJedi
§ith Mã§t€®
Thanks for all the help guys! Turns out the clutch switch just needed to be adjusted a little more. Another turn and a half and everythings working fine now!
Old Dec 14, 2010 | 01:32 PM
DavesZ#3's Avatar
DavesZ#3
Thanks for the followup
_bit
Oct 2, 2015 07:49 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
