Using Floor Jack?
Old Nov 21, 2003 | 09:22 AM
MSOsr's Avatar
MSOsr
Default Using Floor Jack?
For those of you who have used a floor jack in lifting your Z, was there any problem reaching the jacking points with a regular jack, or did you have to use an extended model?
Also, does the Z require the use of one of the low profile floor jacks instead of the standard models?
Thanks. Looking to buy one to use on my car and wanted some tips from those who already use them.
Old Nov 21, 2003 | 09:25 AM
jesseenglish's Avatar
jesseenglish
I have a somewhat low floor jack and what I usually do is drive my car up onto a 2x4 piece of wood to allow enough clearance to fit the jack under it. Otherwise the jack will hit the bottom of the car body.
Old Nov 21, 2003 | 12:47 PM
MSOsr's Avatar
MSOsr
Can anyone tell me the brand/model of floor jack they use on their Zs?
Old Nov 21, 2003 | 05:20 PM
MSOsr's Avatar
MSOsr
Does anyone use a floor jack and jackstands?
Old Nov 21, 2003 | 05:51 PM
ZilvahZ's Avatar
ZilvahZ
Always use floor jacks when you work underneath the car. Takes one accidental kick to the floor jack and it COULD release and you'd be eyeball to eyeball with anything that's crawling on the floor. Anyone remember the old "bumper jacks" that came with most American made cars back when? They use to "creep" on you if not well positioned. This use to scare the cr*p out of me...4K pounds of steel on your foot.
Old Nov 21, 2003 | 06:27 PM
Z'd's Avatar
Z'd
as long as you have a floor jack that will lower enough to clear the bottom of the car, you should be fine. What you really need are these blocks, or something similar, which will allow you to straddle the jack points
http://www.jcwhitney.com/webapp/wcs/...X&appId=385505
Old Nov 28, 2003 | 06:44 PM
jor8888's Avatar
jor8888
I bought a new hydraulic jack that looks like the stock one from Walmart for $14, got tire of spinning the wrench.
Old Nov 28, 2003 | 07:32 PM
joebva's Avatar
joebva
I bought one of these:
http://www.sears.com/sr/javasr/produ...id=00950143000
from Sears. It has a 21" lift (for SUVs). It fit under fine on a flat garage floor.
Old Nov 29, 2003 | 04:14 PM
jackwhale's Avatar
jackwhale
We bought a lightweight aluminum low profile jack. U S General (made in China). I can't remember where I ordered it from. Many autocrossers use them. They're a cheaper version of the higher quality american lightweight jacks.
I also made little ramps from 2 x 10's which I cut at an angle and stacked so that I can drive up and lift the front wheels 4" off the ground. I don't need a jack to change the oil/filter.
With the ramps, our old Sears standard floor jack works.
I'm guessing that ZilvahZ means 'jack stands' instead of 'floor jack' when working under the car. One should never get under a car when it is supported only by the jack.
Old Nov 30, 2003 | 03:16 PM
ZilvahZ's Avatar
ZilvahZ
Yes, that's what I meant..thanks Jackwhale!
Old Nov 30, 2003 | 03:17 PM
jackwhale's Avatar
jackwhale
I bought the lightweight (35 lb) floor jack at harborfreight.com.
Old Dec 1, 2003 | 06:07 AM
vincenzobar's Avatar
vincenzobar
wall mart 2.5 ton jack and jackstands cost 50 bux in total and that 4 jack stands
I use the jack in trunk to lift a little then the hydrolic jack works fine all the way around
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
CJs_Z33
Sep 18, 2015 12:06 PM
ddegrande21
Sep 6, 2015 11:15 AM
