After new parts car is still overheating..
Old Jan 2, 2011 | 09:14 AM
cityslick43's Avatar
cityslick43
Default After new parts car is still overheating..
Hello everyone, My car is overheating, when I take it on the road in about 1 minute the c/h gauge seems to elevate and another minute the car is overheating. I never drive when the temp is all the way up. I took it to a dealership for a diagnostics check and they said leak in radiator and a bent coolant pipe, they bent the pipe back as far as they could. I changed the radiator, (brand new) and put new coolant, and put a brand new thermostat in the car. After all of this work the car is still overheating and there are no leaks! The fans both spin and Im not getting heat in the cabin. Dealer said its not head gasket, so what is left, what can I do? Help please, I really wanna drive my car!
Old Jan 2, 2011 | 09:19 AM
huyrua's Avatar
huyrua
Did you try bleeding all the air bubble out? The 350z are notoriusly known to PITB to get rid of air bubble in coolant system.
Old Jan 2, 2011 | 09:20 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
sounds like air behind the thermostat.
No heat means heated coolant isnt circulating through heater core.
Old Jan 2, 2011 | 09:43 AM
cityslick43
I think I need a new heater core. I did bleed the air out, the hose connected to the radiator that goes to the thermostat is cold and never warms up. I think its heater core.. you guys think so?
Old Jan 2, 2011 | 10:21 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
Hmmm....
You like buying parts for no reason?
Not having heat does not mean your heater core is bad. It still sounds like your thermostat is not opening and therefore not circulating coolant back to the radiator (hose cold, no heat, overheating motor).
Old Jan 2, 2011 | 10:29 AM
shingr's Avatar
shingr
Assuming you have a good working thermostat..
With the motor running and warmed up and heater full on you should bleed the system at the cap at the hose on the side of the engine nearest the battery.
Old Jan 2, 2011 | 10:38 AM
cityslick43
I did bleed the air, and since the hose is that connects the thermostat to the radiator is still cold, should I buy another new thermostat?
Old Jan 2, 2011 | 10:45 AM
cityslick43
After I put the new thermostat everything is was running GREAT I kinda accelerated reved really high it was fine until the next day then the c/h gauge started acting up again.. and I would only get hot air when I accelerated, now one minute into driving it overheats.. Im in Minnesota and its winter, could the cold weather be a factor? new thermostat? again..
Old Jan 2, 2011 | 01:28 PM
ImWeeZzel's Avatar
ImWeeZzel
how many new thermostats have you bought? reason i ask is becuase i replace mine w/ an autozone one, and it was garbage. the nissan oem are better. it could be that you still have air aswell. our cars are known to get air in the cooling system...
Old Jan 2, 2011 | 01:43 PM
cityslick43
Just one from Oriely;s auto like $20 but I think its the heater core! how do i fix that? diagram? will a coolant flush get the gunk out?
Old Jan 2, 2011 | 02:26 PM
ImWeeZzel's Avatar
ImWeeZzel
try another thermostat. simply remove yours and ask for another. I would do that before I get started on the heater core. gl
Old Jan 2, 2011 | 05:29 PM
cityslick43
I will, but before I do that I drove my car about 5 miles today and it didnt overheat. I did add about a liter of coolant.. but i dont get how its off and on like that. Could that possibly be the heater core?? I only get heat when I accelerate and maybe theres more pressure for heat to get through if its clogged.. How can I unclog heater core without taking dash apart..
Old Jan 2, 2011 | 06:20 PM
DaveJackson's Avatar
DaveJackson
Master
Describe in detail the exact steps you did to ensure that there is no air remaining in the system.
Old Jan 3, 2011 | 04:36 AM
silvertouringz's Avatar
silvertouringz
exact same heating issue happened with me a month ago..i bled the system a zillion times. next day i chaged the thermostat and till now everything is awesome
Old Jan 3, 2011 | 05:16 AM
PerfZ's Avatar
PerfZ
It can take multiple attempts at bleeding to get all the air out - you can test a thermostat by dropping it into boiling water - if it doesn't open it's bad. It's been years since I had to replace a thermostat but I always test the new one just to be sure, and I have had some bad new ones over the years.
Old Jan 3, 2011 | 09:28 AM
ImWeeZzel's Avatar
ImWeeZzel
^ ^^ that's a good idea, I'll do that next time I buy a thermostat
Old Jan 3, 2011 | 10:24 AM
cityslick43
I think the heater core is clogged would a coolant flush work?? Can i unclog it without taking my dash apart
Old Jan 9, 2018 | 11:39 AM
Anthony Favela's Avatar
Anthony Favela
i have the same problem but havent done anything yet let me know if you fixed it or if any one knows the solution. im going to bleed it tomorrow morning to see if that fixes it
Old Jan 10, 2018 | 06:34 AM
Atreyu'z 350's Avatar
Atreyu'z 350
Here ya' go.. It gets old typing these steps over and over and over again.. BTW, welcome.
https://www.google.com/search?q=how+...w=1583&bih=499
JjL
East Canada
Jun 12, 2019 03:04 AM
StreetStandard
Videos
Feb 4, 2016 09:44 AM
Juztin
Nov 22, 2015 07:03 AM
carid
Misc.
Sep 10, 2015 06:16 AM
