TPMS Question
Old Jan 5, 2011 | 11:09 PM
RodgePodge's Avatar
RodgePodge
Default TPMS Question
I've done some searches but never really found the clear cut answer I've been looking for.
I've got the (!) light on on my dash and my PSI indicator displays --.
I understand I've got a tpms malfunction so here's my question:
Do I need to buy a new sensor and have it synced? Or can I have it reset at one of the various reputable tire shops in my area?
Thanks in advance for any help!
RP
Old Jan 6, 2011 | 03:12 AM
DavesZ#3's Avatar
DavesZ#3
You can try to get it reset but chances are pretty good you're gonna need a new one then have it synched up to the computer.
Old Jan 6, 2011 | 07:06 AM
RodgePodge's Avatar
RodgePodge
Crap! That's what I thought I was going to have to do. Thank you for confirming for me. Is there a vendor here where I can buy a tpms sensor from?
Thank you for the reply!
Old Jan 6, 2011 | 08:48 AM
c0ld29's Avatar
c0ld29
Here is a link on how to sync it properly once you get a new one installed (or just to reset it). Save money from the dealer (and probably a tire shop if they have the tool, but call around they might do it for free or cheap while they install the sensor)
https://my350z.com/forum/maintenance...ring-tpms.html
Now as far as buying one, they have a shelf life so I don't suggest buying a used one, but there are many places that sell them. Autozone and places like that sell them, but the cheapest I've found is from rockauto. I'm not sure if any vendors on this site in particular sell them, sorry.
Old Jan 6, 2011 | 10:15 AM
RodgePodge's Avatar
RodgePodge
Would you recommend just buying 4 brand new ones and replace/sync them all in one setting? Seems pretty logical if they have a shelf life and this one went out.
Thanks for the link!
Old Jan 6, 2011 | 02:06 PM
c0ld29's Avatar
c0ld29
Well its up to you on that really. I have one thats currently out and I think I'm just going to order that one for now, but thats because I still owe tuition and books for this upcoming semester. If you can part with the $200 for the sensors and the extra to have a shop replace them then it would save you some time down the road. If i recall correctly I believe the life of them (depending on how much you drive of course) is supposed to be around 5-6 years.
Old Jan 6, 2011 | 05:25 PM
RodgePodge's Avatar
RodgePodge
I still owe fees and books(if I buy them) for intersession and the spring semester. I'll make some calls to some local shops to get some quotes and then determine whether or not I want to replace and sync all of the sensors.
Thanks for your advice!
RP
Old Jan 19, 2011 | 08:56 PM
RedlineAZ's Avatar
RedlineAZ
Hey man I don't mean to thread jack, but mine is doing the same thing and this could help you save some time also. Mine would flash, and then stay lit, while reading (--) on one of the back tires. I went to discount tire and they reprogrammed em, and said all the sensors are working properly but for some reason one just needed reprogramming. Well that was yesterday, and today its back on doing the same thing! Does the sensor need replacing or is there another trick? The tire is not losing air.
Old Jan 19, 2011 | 09:34 PM
RodgePodge's Avatar
RodgePodge
Hey, mine was doing that so I replaced the sensor and had it synced but it still displayed (--) on the right rear tire. I'm going back tomorrow to have them all resynced to see if that solves the problem. I'm pretty sure that the sensor needs to be replaced. As far as it temporarily working again... I don't know what to say about that. I'm still learning so my knowledge isn't that great. I'll let you know what happens after my appointment tomorrow. Good luck!!
Old Jan 20, 2011 | 06:15 AM
RedlineAZ's Avatar
RedlineAZ
Thanks man! My right rear tire was the one displaying (--) and I had them all resynced and the next day the same tire was reading (--) again. If you replaced your sensor and its still reading like that, I wonder what else can cause it.
Old Mar 4, 2011 | 07:52 AM
chowg's Avatar
chowg
What ended up happening with this? I have the same problem! Thanks!
Old Mar 4, 2011 | 08:16 AM
RodgePodge's Avatar
RodgePodge
I first took it to a tire place because they said it'd be no trouble at all to fix. They ended up clearing ALL of my sensors and told me I'd have to have a dealership do it. So I went to the dealership and they replaced the malfunctioning sensor and reset the other sensors. Now everything is working the way it should. Total cost ended up being about $90. Kind of costly but it's fixed!
Old Mar 11, 2011 | 06:29 PM
rich2342's Avatar
rich2342
Can anyone explain mine case?
I have stock 18's touring rims without tpms sensors. They have rubber stems. They light is not illuminated on my dash, however it does come on from time to time but shuts off if I shut down??
What would cause this?
Old Mar 11, 2011 | 06:42 PM
surfcity40's Avatar
surfcity40
If you have no sensors, the indicator light comes on after a set number of miles have been driven in one drive time and when the car is turned off it doesn't come on again until you do that again.
Old Mar 23, 2011 | 02:50 PM
Diesel350's Avatar
Diesel350
One of my TPMS sensors is reading a "0" but I have full air in the tire. Does the sensor just need to be reset?
Old Mar 23, 2011 | 03:36 PM
DavesZ#3's Avatar
DavesZ#3
If it reads "--" then there's no signal and resetting might help. Reading 0 would suggest the sensor has failed but there's no way to know for sure unless you get it checked/tested. If you can get it reset for free, certainly try that first.
Old Mar 24, 2011 | 03:59 PM
RedlineAZ's Avatar
RedlineAZ
Discount tire (america's tire) by my house resets/reprograms TPMS sensors for free! They did it for me on my 350z, and on my corvette! And I didn't even purchase any tires from them
issyz
Jul 2, 2017 03:04 PM
