car's eating through oil.
Old Mar 7, 2011 | 03:19 PM
Originally Posted by ratz1400
Would it be a bad idea to get an extended warranty and wait a few weeks to bring it in?
Will not work. An extended warranty will not cover current problems. No mechanic will believe that the motor suddenly began consuming oil in a week.
Old Mar 9, 2011 | 05:57 AM
infamous350's Avatar
infamous350
Yeah thats not good. WHen my car had that many miles it burned zero oil. It has 140k on it now. I burn a quart every 1000 miles(Nissan states 1quart per 1k miles is normal). it still put down almost 280whp. But i drive 100 miles a day and beat the living **** out of it. More then you could imagine i want to blow the motor up so i can do a rebuild lol. Anyway i have 12 quarts of amsoil at my house i was using mobile 1 extended since i bought the car in 05 with 12k miles on it. I have feeling the amsoil is gonna fix or reduce the oil consumption. My friend is raving about this oil. Also ill bet your valve cover needs to be changed and not cause of a little oil residue around were the seals. Its leaking oil in the plugs most likely and the o rings are not replaceable check the passenger side.
Old Mar 10, 2011 | 01:32 AM
Lee R's Avatar
Lee R
Amsoil fixing the problem? Replacing a gasket? I'm telling you man...do a proper leak down test.
Old Mar 10, 2011 | 05:00 AM
infamous350
its not leaking well my car. Its burning. you'd be surprised my friends car completely stoped lburing any oil when he put amsoil and his valve ticking completley went away
Old Mar 10, 2011 | 08:15 AM
Lee R's Avatar
Lee R
A leakdown test doesn't measure or see where the oil is actually leaking!
It measures how much oil is leaking past the cylinder and burning off on the plugs and or out the tailpipe in ugly thick grey/black smoke. Ugh......
Old Mar 10, 2011 | 07:19 PM
winchman's Avatar
winchman
I've done dozens of cylinder leak down tests. They only measure how much air is leaking past the rings and valves seats with the piston at top dead center. They tell you nothing about the condition of the cylinder further down the bore, where the side loading on the piston sometimes causes more wear. They don't tell you anything about the condition of the valve stem seals, either. Consequently, the test will not always tell you where the oil is getting into the combustion chamber.
The test will tell you something about the overall condition of the engine, though. If there's a lot of leakage at TDC , you can assume the cylinders/rings and/or valves/seats are in bad shape.
Old Mar 14, 2011 | 06:51 AM
trusovici's Avatar
trusovici
yea check your valve cover seal. an easy way to check is to take out your plugs and see if they are covered in oil. if so, your probably leaking from there into the cylinder.
Old Mar 14, 2011 | 08:26 AM
abretz89's Avatar
abretz89
Hey guys, I just bought my 06 a few months ago and did the first oil change last week. Didn't see any leaks after driving the first few days then I did a highway run up to 120 and when I got off the exit and parked a few miles away ive got smoke billowing from the hood. I assumed maybe coolant bubbled over from the reservoir since I topped it off a tad over the max line. Another few days of normal driving and no problems. Then last night jumped on the throttle to pass someone and smoke out the tailpipes and slight burning smell when I got out of the car. I did notice a small drop of oil under where I parked but haven't gone under to see where it came from. Any ideas on how bad it might be? It's at 59,500 miles so I have a touch of warranty left. Should I just take it to Nissan before the coverage runs out?
Old Mar 14, 2011 | 02:23 PM
winchman's Avatar
winchman
There's absolutely no way oil from a leaking valve cover gasket can get into the cylinder until you loosen/remove the spark plug.
Old Mar 14, 2011 | 02:40 PM
Shawz1102's Avatar
Shawz1102
Wait, Nissan said our engine is supposed to burn 1 qt ever 1,000 miles? For full synthetic oils that only needs to be changed every 10,000 miles (according to oil manufacturer), our engines would be oil-less by the time we reach 10,000. Is this right?!
Old Mar 14, 2011 | 02:55 PM
DaveJackson's Avatar
DaveJackson
Master
Right. He must have meant the "cylinder" area where the spark plug lives.
Old Mar 14, 2011 | 05:13 PM
trusovici's Avatar
trusovici
oh yea and check the seal around your dipstick, if its ripped it will **** out oil onto the exhaust manifold and burn. when i bought my z the rubber seal at the top of the dipstick was torn and would leak. drove me nuts until i noticed it. brought it to 3 shops and they had no idea.
Old Mar 14, 2011 | 06:19 PM
infamous350
Yeah nissan told me a quart of oil every 1000 miles is normal on performance vehicles lol. I think the person who drove it the first 17k didn't break it in properly or something. Or maybe i just beat on it to much
Old Mar 16, 2011 | 10:30 AM
ratz1400's Avatar
ratz1400
Well I just got my car back and they changed my pcv valve and said it solved the problem.. I'm not home to check so idk but I hope that's it
Old Mar 16, 2011 | 01:08 PM
winchman's Avatar
winchman
Well, heck. There was another thread where I suggested the PCV valve could be the culprit, but the symptoms were different from what you posted.
https://my350z.com/forum/engine-and-...-symptoms.html
I hope the fix actually solves your problem. That was probably not horrendously expensive.
Old Mar 16, 2011 | 01:56 PM
dmroberson's Avatar
dmroberson
No. Nissan recognizes 1 quart every 1000 miles as excessive oil consumption. The consumption rate accepted by Nissan is up to 1 quart for the life of the oil change interval.
Old Mar 28, 2011 | 09:59 PM
abretz89's Avatar
abretz89
Thanks for that post. It didnt even dawn on me to even think that would be the culprit but sure enough, chunk missing from the rubber seal where it seats. Trip to Nissan and a new dipstick solved that problem. How the previous owner and/or nissan dealership I bought it from missed this is beyond me.
Old Apr 16, 2011 | 01:12 PM
  #38
Steve-O Z33's Avatar
Steve-O Z33
Mine recently started going through A LOT of oil. I have 2k on my last change and I've added 1.5 quarts. No smoking, car runs great. But the oil disappears. No dripping in the driveway.
I just checked my dipstick last week and it's ripped. There is also oil all around it and on the hoses near it. So that's got to be my culprit. A few weeks ago, I replaced the PCV just to be sure. Oh well, at least I know. The 03-06 dipstick is just a joke. Bad location and the rubber breaks off, causing a bad leak. Until this must have melted/broke off/whatever, the car really didn't burn oil. So I was a bit worried to see myself 1/2-1 quart low after a long drive. In 250-ish miles of driving, it's about 1/2 a quart low right now. So dumping that much German Castrol in between a change gets expensive. I'm definitely going longer between this change since I've added nearly 2 quarts.
etkms
Jun 19, 2022 06:30 PM
StreetStandard
Videos
Feb 4, 2016 09:44 AM
