Problem with the oil pressure gauge! Plz help!
Old Mar 10, 2011 | 10:16 PM
cityslick43's Avatar
cityslick43
Default Problem with the oil pressure gauge! Plz help!
Hey everyone I am in serious need of some advice! I recently got an oil change about a week ago...
... but this problem started about 2 days ago.
When I drive my Oil gauge on the dash passes 120 psi!! its at the very end of the gauge even when I leave the car off for a while! Do I need to add oil? Is there a leak?? What should I do?
also.. is it safe to drive it with it like this? The c/h gauge is normal
please help... its an 05 automatic 350 z
Old Mar 10, 2011 | 10:53 PM
dirtbikr's Avatar
dirtbikr
At the top of the page you are currently looking at, navigate to DISCUSSION FORUMS --> 350Z TECH FORUMS --> Engine & Drivetrain. Once you arrive on that page, click on the search button, very visible in the upper right hand corner of the forum (placed there for your convenience). Search for "oil pressure gauge problem" without the quotes. It seems that Dr.Tub has done this before you, as have many, many, many, many others. Please join them.
Old Mar 11, 2011 | 03:27 AM
As dirtbikr mentioned. Please search "oil pressure sensor." Very popular subject.
Old Mar 11, 2011 | 05:47 AM
tylerxfire's Avatar
tylerxfire
as stated oil psi sensor other known as oil sending unit...very common..easy fix..if u searched for 2 seconds it would have came right up..
Old Mar 11, 2011 | 07:20 AM
AngelsVQ's Avatar
AngelsVQ
Old Mar 11, 2011 | 08:47 AM
cityslick43
Well if it is just the sensor can I still drive the car for a bit until it is fixed? and where is it located?
Old Mar 11, 2011 | 09:41 AM
drivessidewayz's Avatar
drivessidewayz
Old Mar 11, 2011 | 12:58 PM
cityslick43
ok what was the point of that? waste or energy
Old Mar 11, 2011 | 01:34 PM
Not certain if oil pressure is 120 PSI or the sensor is giving you a false reading. Do you feel comfortable driving the car?
Old Mar 11, 2011 | 04:18 PM
cityslick43
The car is driving a but funny laggy on the acceleration..
Old Mar 11, 2011 | 04:37 PM
surfcity40's Avatar
surfcity40
The point was that as this site has obviously been around since before the 350Z came out, this question has been asked and answered innumerable times. This was pointed out to you and rather than exploring and finding the answers to your query, you chose instead to ask additional questions about the problem that has been asked and answered many times.
But you're special. Since you're special I'll search for you. Here you go:
this thread shows you where it is
https://my350z.com/forum/engine-and-...re-sensor.html
you can get it here
http://www.courtesyparts.com/25070-s...tml?cPath=714&
here are a couple (of the hundreds) who had your problem.
https://my350z.com/forum/maintenance...ding-unit.html
https://my350z.com/forum/maintenance...il-change.html
Old Mar 12, 2011 | 06:19 AM
tylerxfire's Avatar
tylerxfire
dont drive the car...think about that for a second..jesus christ...do some damn research instead of looking to be spoon fed...it is near the oil filter and screws into the block on one side and a clip on the other side for a connector...RESEARCH
Old Mar 14, 2011 | 04:19 PM
cityslick43
Is it ok to drive the car short distances until it is changed?
Old Mar 15, 2011 | 05:50 AM
tylerxfire's Avatar
tylerxfire
omfg..no do not drive it..get it fixed it doesnt take long and isnt an expensive fix..why cause more of a problem
if u think 120+psi of oil pressure is good then go right ahead see how that goes..
Uriyo_
Sep 8, 2021 08:46 AM
