Oil Leak | Oil Pressure Sending Unit
Old May 13, 2010 | 11:33 PM
AgentReaver's Avatar
AgentReaver
Default Oil Leak | Oil Pressure Sending Unit
Hey everyone,
I just got my summer tune-up underway and ran into a bit of an issue. After changing my trans, diff and engine oil, I decided to replace the Oil Pressure Sending Unit since my gauge was acting wacky. With the engine oil drained, I removed the old OPSU with a 15/16 wrench and installed the new one with some threadlock. It fit tight and no leaks were apparent, even the gauge was finally working again!
I took my brother's car to work since I wanted to change the belts and such on my Z when I got home.
After returning home I noticed a small puddle of oil under my engine. I raised the car and wiped everything down. And noticed it was coming, very slightly, from the new OPSU. I removed the OPSU, cleaned the threads, applied threadlock and a slight bit of Hondabond (silicone oil resistant sealant) to the base. I let the car sit for about 15 minutes and no oil was leaking. After firing up the car and lowering it once again, I noticed the drip had returned. Does anyone have any experience with changing this out? If so, what am I doing wrong that I am getting a leak?
The OPSU is located by the oil filter, right next to the oil cooler/heater and it's corresponding hose.
Thanks,
AR
Old Jun 6, 2010 | 06:31 AM
rwm10's Avatar
rwm10
Bump!
I have to replace mine soon as well, so I'd like to know if this is a common problem, and what the best method to fix it is.
Old Apr 20, 2016 | 04:48 PM
Abe_Froman's Avatar
Abe_Froman
Did you ever fix the leak? I am having the exact same issue.
Old Apr 20, 2016 | 04:59 PM
travlee's Avatar
travlee
Master
agent hasn't logged in going on 5 years
rwm going on 2 years....
might be waiting a bit for them to respond
Old Apr 20, 2016 | 05:52 PM
Abe_Froman's Avatar
Abe_Froman
Yeah, figured as much.
Old Apr 20, 2016 | 06:01 PM
travlee's Avatar
travlee
Master
but... tell the forum exactly what is going on, what lead up to it, what you have done, et etc and you will most likely get some help
Old Apr 20, 2016 | 06:05 PM
Abe_Froman's Avatar
Abe_Froman
Replaced the oil pressure sending unit with one from Autozone. Thought I had it torqued right but it drips a few drops on the ground per day. Ive tried loosening it a bit and tightening it a bit but it still leaks. It is threaded in about halfway just like the original. I ordered an OEM sensor from Nissan to see if that might have a better fit but I'm at a loss on how to stop this leak. Maybe some plumbers tape on the threads?
Old Apr 21, 2016 | 05:25 AM
rancor's Avatar
rancor
My guess is plumber's tape or liquid plumbers tape but use sparingly. Only wrap the last few threads that go into the engine you do not want PTFE(teflon) in your oil system.
"BSPT (British Standard Pipe Thread) is similar to NPT except for one important difference. The angle across the flanks of threads (if you sliced the fitting in half long-ways and measured the angle from root to crest to root) is 55 degrees instead of 60 degrees as it is for NPT. Thus an NPT male will fit into a BSPT fitting or vice versa but they will not seal. This is a popular fitting in China and Japan but is very rarely used in North America unless the equipment to which it is attached was imported. Thread sealant is needed to seal the male and female fitting together."
Old Apr 21, 2016 | 09:07 AM
Abe_Froman's Avatar
Abe_Froman
I picked up some high temp thread sealant which I will apply to the old sensor and see if that does the trick. If it doesn't I'll try the new OEM sensor. Hopefully one will resolve the issue.
Old Apr 29, 2016 | 02:11 PM
Abe_Froman's Avatar
Abe_Froman
The thread sealant seems to have done the trick.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
