Stock Z Alternator Output?
Old Apr 6, 2011 | 04:20 AM
BlizagaXx's Avatar
BlizagaXx
Default Stock Z Alternator Output?
Hey guys, what voltage does your stock Z put out on the volt gauge? I keep popping ballasts in my 03 touring (OEM HID) and I have no idea why. I noticed my voltage IS kind of high, like 15 always, but it goes up to 15.5v, maybe even more. I never really paid attention to the voltage gauge though so this may be how it operated the whole time. I never really had a reason to check the gauge, I'm stock. I was thinking maybe the voltage regulator in the alternator might be bad.
Old Apr 6, 2011 | 06:13 AM
DavesZ#3's Avatar
DavesZ#3
Normally, alternators put out about 14+ volts. Per the FSM, the regulated voltage should read between 14.1 and 14.7 volts.
Old Apr 6, 2011 | 06:54 AM
drivessidewayz's Avatar
drivessidewayz
My Z and crv are, as Dave said, between 14.1 and 14.7; typically 14.4
Old Apr 6, 2011 | 07:19 AM
diablox1's Avatar
diablox1
15.5 is too high for consistent, steady state output. normal range is like stated above, with acceptable and very rare fraction-of-a-second spikes into the 15s, but never constant and all the time. get your alternator checked out
Old Apr 6, 2011 | 07:48 AM
DFW Z33's Avatar
DFW Z33
I am salad
mine puts out 14 on the dot when driving
Old Apr 6, 2011 | 09:35 AM
BlizagaXx's Avatar
BlizagaXx
Yeah I though that's what it was supposed to be. I'm by no means a rookie when it comes to working on cars, I just didn't know if Z's ran higher. Like I said, never had a reason to look at the volt meter until now. There's a shop by my house that rebuilds alternators so I'll have him take a look at it.
Thanks guys!
Old Apr 6, 2011 | 11:15 AM
christol's Avatar
christol
Thanks guys!
If you have a good voltmeter of your own, check it at the battery. Check at idle and at 2k rpm. OEM voltmeters seem to guesstimate quite often.
Old Apr 6, 2011 | 04:06 PM
BlizagaXx's Avatar
BlizagaXx
I've got a Fluke multimeter I'll check it with thanks.
Old Apr 6, 2011 | 11:27 PM
winchman's Avatar
winchman
I heard a joke once about a high voltage reading being just a fluke, but I can't remember how it went.
derekinthez
South East
Sep 28, 2015 06:35 PM
