ac amp climate control, flat cable
Old Apr 20, 2011 | 01:44 AM
kisser's Avatar
kisser
Default ac amp climate control, flat cable
Hi everyone
sorry for my english but i'm italian.
i've buyed an used parts climate control amp for a 06 350z but the flat cable is broken.
how can i fix them? any ideas?
Old Apr 20, 2011 | 04:16 AM
Can you open the plastic box?
1. Cut tape past the broken part.
2. Place inside box. You can see that the end of the tape is folded for strength.
3. Snap box closed.
The box may be heat-closed. If so than it is not user repairable.
Old Apr 20, 2011 | 06:16 AM
bmccann101's Avatar
bmccann101
yeah aside from that Id just get a replacement cable man.. that climate control box is connected to alot of stuff.
I cant imagine its too rare or expensive.
Old Apr 23, 2011 | 09:18 AM
kisser's Avatar
kisser
3. Snap box closed.
epic win! 100 point!
i've open the white box,i've turned the flat cable ed everything works!
Old Feb 5, 2012 | 07:31 PM
longshaw's Avatar
longshaw
Were you able to replace the cable? I have the same problem and need to replace my cable.
Old Mar 11, 2019 | 06:07 AM
damnhippie's Avatar
damnhippie
Anyone know a part number or where to find this replacement ribbon? Some dbag tried to steal my stereo and ripped out this cable from the clip. Must be heat sealed cause I can't seem to open the clip.
Old Mar 11, 2019 | 09:24 AM
beezee's Avatar
beezee
Not heat sealed. I replaced mine twice because I mess with my console a lot. Take out screws to open. Ribbon held in by a flip up and down lock mechanism . You will understand better once opened
Old Mar 19, 2019 | 05:15 AM
damnhippie's Avatar
damnhippie
ok thanks, I'll pull it out and have another look.
Old Apr 19, 2020 | 03:09 PM
Zach Horvat's Avatar
Zach Horvat
Default Ribbon connectors
When you cut the cable. How do you reveal the metal connectors under neath the plastic?
eXr
Cooling System
Mar 14, 2012 07:13 AM
