lsd swap
Old Apr 28, 2011 | 03:27 PM
sonoriansZ's Avatar
sonoriansZ
Default lsd swap
My VLSD went out and I need to know if I need to modify anything or if it needs to be a special kind of LSD. I'm buying a stock lsd. Need some help.
Old Apr 28, 2011 | 05:30 PM
hellsoldiers08's Avatar
hellsoldiers08
how you know if your lsd goes out?? sorry to be off topic..
Old Apr 28, 2011 | 05:56 PM
sonoriansZ's Avatar
sonoriansZ
Well ur LSD is pretty much 2 clutches. They wear out like a clutch. So once ur trying to drift or burn out, the clutches lose grip and one side will just lose traction.
Old Apr 28, 2011 | 06:31 PM
AngelsVQ's Avatar
AngelsVQ
Research man. It's not 2 clutch... Vlsd works with fluid. Do some more research. All everyone is going to tell u here including myself is to buy a real LSD. Oem vlsd is trash
Old Apr 28, 2011 | 08:01 PM
sonoriansZ's Avatar
sonoriansZ
Really? Then I was misinformed! Well now I know! Well if my LSD is going out, do I need more fluid in my differential?
Old Apr 28, 2011 | 10:47 PM
terrasmak's Avatar
Diff fluid is seperate from the VLSD fluid. Once the VLSD fluid has been cooked (usually lasts 2 to 3 trackdays ) it needs to be replaced, there is no rebuild for it. http://www.courtesyparts.com/kb_sear....php?keywords=[38420M]+\(Z33&cPath=714_715_778_798 is the replacement, or better yet, just install a REAL LSD
Old Apr 29, 2011 | 06:15 AM
sonoriansZ's Avatar
sonoriansZ
OK since I'm a newbie to this diff, when I go to buy the LSD does it have to be a certain one cause of my car having the option to turn on and off traction control?
Old Apr 29, 2011 | 07:50 AM
Kwame's Avatar
Kwame
No.
Decide what your future use is for your vehicle and your budget for the LSD and make the proper purchase the first time around.
Old Apr 29, 2011 | 10:01 AM
terrasmak's Avatar
As Z1 said, not at all. My VDC functions just fine with my OS Giken unit installed (Ordered from Z1)
Old Apr 29, 2011 | 12:49 PM
AngelsVQ's Avatar
AngelsVQ
If you want a prety smooth diff that requires no maintenance look into a Quaife 1.5 way
Old Apr 29, 2011 | 01:04 PM
dcains's Avatar
dcains
I'm still curious about what you mean when you say, "My VLSD went out . . .". Please share the details.
SpartanZ32
Oct 22, 2015 09:36 AM
Paul.
Oct 16, 2015 07:34 PM
SharX59
Sep 27, 2015 09:23 AM
3vilbunny
Sep 13, 2015 12:31 PM
