Window issue
Old Apr 28, 2011 | 03:35 PM
bankswood's Avatar
bankswood
Default Window issue
My daughter has a 2005 350Z. We are actually joint owners. I paid for it and she drives it. Anyway, the passenger size window has been to malfunction. The window goes up and down fine when you use the window switch. The problem is that when you open the door the window will go down an inch but will not go back up when you close the door. Is this a relay or some sort of switch problem. Any help is muxh appreciated
Old Apr 28, 2011 | 05:44 PM
akdnj88's Avatar
akdnj88
Try reset the window motor. The reset button is located on the motor (you have to pull the door panel off to do so). Look for the procedure on how to do it.
Old Apr 29, 2011 | 12:10 PM
andrew's 350Z's Avatar
andrew's 350Z
^^ exactly. Search the forums and u will find how to do it. It will take about 30min
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
