Check Engine Light Help!
Old May 1, 2011 | 01:46 PM
Awscoonce's Avatar
Awscoonce
Default Check Engine Light Help!
Ok so here is the deal i just installed a double din in dash dvd player and tried to start my car without connecting the white box and got all the lights on my dash bored to light up. once i realized that i did this i plugged it back in and started it back up. All the lights went out except the the check engine light. Idk what the hell happened. its an 03 touring. Idk if i have to reset the ecu or just unplug the battery. Any help would be appreciated
Thank you,
AWS Coonce
Old May 1, 2011 | 02:37 PM
DavesZ#3's Avatar
DavesZ#3
Pretty common problem. Either get the CEL cleared or disconnect battery overnight and that will reset it.
Old May 1, 2011 | 02:41 PM
Awscoonce's Avatar
Awscoonce
Thanks man ill look into that and get back to you
Old Jun 21, 2011 | 04:52 AM
RENFRO's Avatar
RENFRO
Hey man, just fyi I did the ECU reset procedure (5 gas pedal press prodecure) and it worked. I'll let you know if the codes come back up
Old Jun 24, 2011 | 02:00 PM
RENFRO's Avatar
RENFRO
Codes came back. They only showed up after this stereo install. Should I disconnect the battery over night?
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
