I have a 2004 350z. The top closes ok, but when opening the top after at has been closed for a few days...the lid goes up 1/4 of the way and stops. I bump the switch two more times and it goes all the way and works fine the rest of the day. Sounds like I need to replaces brushes in the two convertible top Motors. Are the brushes the same size and is there a video out there showing how to remove the motors? What is 5th bow? Is there a 1st, 2nd, 3rd and 4th bow??
According to service manual to access roof actuators one needs to uninstall roof assembly. It's like a first step in the guide. However the same is true for 5th bow motor, which people learned to remove without even touching the roof assembly itself.
I have similar symptoms to yours, and replacing brushes 5th bow motor didn't fix help much, so the only option left is roof actuators, but even after reading service manual and looking at it on the car I got no idea how to replace them without removing the roof completely. Let me know if you figure out the way.
I am new to the forum and have a convertible 2006 350Z with 6 speed MT. The car is in mint condition with low miles and I am trying to keep it clean.So reading all I can to learn about the convertible top. Is there a procedure on how to grease those areas in order for the top to stay functional?
thank you.
I believe the discussed situation cannot be prevented by greasing or anything like that, it's just the way brushed motors work — brushes wear out and the only way to save the motor is replacing them.
thanks i understand that. My car is 2006 and has only 51K on it. the previous owner kept it in the garage and looks like trunk was never used. In reading one of these posts someone suggested to keep the linkages lubricated every few years or so to keep the top functioning properly. Motor issues I understand
I check the elastic straps and they are not that elastic so i will be replacing those soon. Will check with the dealer to see how much they charge to replace or other local upholstery shops here in Tulsa area.
The motors can be removed by removing 2 bolts and 1 nut. Very simple. Will post pics when brushes come in this week and I re-install motors. Nissan will only sell you an "assembly" which has motor installed on part of the convertible top frame work, which would be a LOT more intense.
Wow, that'd be highly appreciated! Could you also share brushes dimensions for these motors? And where did you order them?
A tiny update on 5th bow motor brushes dimensions:
8-10 is approximated length of the new brush, I installed 10mm and it barely fitted: the spring could barely reach the end. Of the brush.
Also to note that the material is not a regular graphite, rather some mix with copper or some other metal.
Hey, sorry for bringing up an old thread, it seems like it was very detailed with the picture explanations but the pictures don't show up. Is it just me, or were the pictures taken down or something?
I recently had my 5th bow motor rebuilt by a guy in Florida. He did a great job. I found him on eBay. I just posted a video on Youtube describing my reinstall of the motor. It is a pain in the *** but hopefully, the video will help make the pain easier. Just remember how much you are saving doing this yourself.
I also had my motor rebuilt by professionalserviceinc. I was fortunate enough to find his link on ebay.com. The turn around was phenomenal. I had to glue a Phillips head socket into a socket in order to the back screw out. I wouldn't hesitate recommending this repair. The cost of a new motor is ridiculous.
