rack n pinion knowledge?
Old May 22, 2011 | 03:29 PM
Mcutali's Avatar
Mcutali
Default rack n pinion knowledge?
so last night i ran around with some buds cruising in our z's i heard some noises realized my undertray had come off at 90mph so today while fixing and bolting up the rear part of tray i noticed this nut on the back of the rack and pinion was filthy i ran my finger over it to find it sludgy oil seeping out. tightening this nut will this solve the issue at hand? or is there seals or something to be replaced, the vehicle is a 2004 touring 6speed 350z 70,067 on the clock. it is lowered on tein basics lowest setting in rear about 1.5in front drop, anyone with knowledge please chime in thanks
Old May 22, 2011 | 03:32 PM
Amirs350z's Avatar
Amirs350z
Couldn't hurt to try and clean it up and tighten it. What's the worst that could happen? Obviously, I'd call a dealership or google the torque specs. Other than that, I can't see anything being too detrimental from doing the aforementioned activities to that bolt.
Old May 22, 2011 | 04:51 PM
jerseystyle's Avatar
jerseystyle
Old May 22, 2011 | 07:11 PM
xpertool's Avatar
xpertool
ur Pinion seal is probably leaking I only had 35000 miles on my 08 350Z 6speed manual when mine started leaking not only that my tranny oil seal was leaking too so I had both replaced under warranty.
Old May 22, 2011 | 11:27 PM
Mcutali's Avatar
Mcutali
Question ,
Uploaded with ImageShack.usthis is where im leaking, i have impact sockets this big but they will not fit in the space to tighten this down, im looking into some wrenches metric 22 and up, i do not wanna use channel locks, dont wanna mar the bolt. if i were to remove this bolt drain the system, where is the seal? behind this bolt or somewhere else? and then how do you fill this system back up?
Old May 23, 2011 | 03:58 AM
winchman's Avatar
winchman
I think that's a screw for adjusting the contact pressure between the pinion and the rack. You probably shouldn't just tighten it. It's probably adjusted with some sort of thread locker or sealant on the threads to keep it in place.
You should get section PS of the service manual for your year for the details.
Old May 23, 2011 | 02:33 PM
Mcutali's Avatar
Mcutali
Alldata doesnt get in depth it. I need mitchell. Find it hard to find much of any info rack pinnion period on 350z except some accounts of them leaking
Old May 23, 2011 | 03:13 PM
winchman's Avatar
winchman
This might help.
The adjuster parts are in the lower right corner. You can get more info about them here:
http://www.courtesyparts.com/350z-pa...5_815_821.html
Section PS of the service manual says to use "Three Bond 1111B or equivalent" on the adjusting screw.
You might see this thread about getting a service manual for your year:
https://my350z.com/forum/maintenance...anual-fsm.html
Old Jun 24, 2011 | 11:32 PM
Mcutali's Avatar
Mcutali
Angry
This might help.
49231m seems to be the bolt/nut i see? with car in the air looking forward towards nose cone, where the steering rack meets into the rack itself on the backside of actual rack facing rear is a big nut(bolt)? and i have a what seems to be a small leak. im just looking for the right fix, can i pull this bolt/nut? drain the system..replace a o ring if need..which is what i was thinking is needed.. possibly do all the seals on the lines attached.. replace nut/bolt and new fluid, bleed it. and be done? no? enlighten me please.
off topic, my buddy has a g37s and has had his whole entire rack replaced. at 30k miles. so ive dealt with the outa whack suspension once u lower/ the 6th cyc oil in spark plug tube.. whats next in line thats predictable....
Old Jun 24, 2011 | 11:40 PM
Mcutali's Avatar
Mcutali
Default re
49233a is the actual nut if it adjusts i would agree i shouldnt mess with it but any ideas, im not wanting to replace entire rack just yet. gota sign off here my dog is sick, jeez.
Old Jun 25, 2011 | 05:13 AM
winchman's Avatar
winchman
How much is it leaking? Have you noticed any drop in the level in the power steering fluid reservoir?
If it's not leaking much and you're not having to add fluid very often, I'd just leave it be.
The procedure in the SM for adjusting that screw is pretty involved, and you have to disconnect the steering shaft and tie rods to get it done correctly. You'll also need some special tools. It would probably be best to remove the whole thing from the car if you really need to take it apart. You should do an alignment after reinstalling it, too.
Old Jun 29, 2011 | 12:15 AM
striker27's Avatar
striker27
Having the same issue with my car. It is a 2003 and it leaks from the very same nut.. Actually do notice spots on the ground from the leaking and do have to fill it up every so often... Has any one tried to tighten that nut??
Old Jun 29, 2011 | 08:22 AM
winchman's Avatar
winchman
You don't want to just tighten it. It's an adjustment screw that's sealed with threadlocker. Tightening it too much will make the car hard to steer and/or damage the rack and pinion parts. Read the service manual.
chief3630
Feb 29, 2016 02:54 PM
bcoffee20
Nov 19, 2015 06:39 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
dragon11689
Sep 7, 2015 02:47 PM
ddegrande21
Sep 6, 2015 11:15 AM
