door wont open from inside or out
Old May 25, 2011 | 02:55 PM
my friend's Avatar
my friend
Default door wont open from inside or out
drivers door wont open from inside or out with key and remote i tried everything. Anyone have any ideas? does anyone know a way to remove panel with door closed? its fun getting into a z from pass side but also embarrassing so please help.
Old May 25, 2011 | 04:46 PM
my friend's Avatar
my friend
would a locksmith be able to open this or maybe the cops?
Old May 26, 2011 | 08:25 AM
my friend's Avatar
my friend
So the locksmith came and told me they can't fix that. Nor should I call another one.
Old May 26, 2011 | 08:41 AM
NZMOWND's Avatar
NZMOWND
keep the window down and NASCAR it up!!!
Old Oct 4, 2011 | 05:03 PM
my friend's Avatar
my friend
i don't fit. my torso is too long lol. I just cant believe i'm having the same problem again 5 months later. if anyone has any ideas that i can do please don't hesitate to post
Old Oct 4, 2011 | 06:25 PM
ChuckW's Avatar
ChuckW
Paint 01 on the door.
Old Oct 4, 2011 | 07:07 PM
winchman's Avatar
winchman
It's probably time for drastic measures. Maybe you could get a Dremel tool with a carbide burr, and cut an access hole in the inner panel near the lock mechanism. Then you could get the door open, fix whatever is wrong, and get a replacement panel from a wrecking yard.
This figure from the service manual might help you pick a spot to make the opening. I'd aim for the actuator, item 6 in the figure.
Attached Thumbnails door wont open from inside or out-miscellaneous-cannon-august-2011-on-054.jpg
Old Oct 5, 2011 | 03:27 AM
ChuckW's Avatar
ChuckW
Pull the seats out and you might have the access you need to remove the door panel too.
Just a guess, I haven't honestly had to remove the door panels on the Z.
Old Oct 5, 2011 | 08:34 AM
winchman's Avatar
winchman
The rear edge of the inner panel extends into the recess around the door opening so you cannot remove it when the door is closed.
Old Oct 5, 2011 | 11:03 AM
my friend's Avatar
my friend
https://my350z.com/forum/exterior-an...-position.html
i finally found someone with the same problem or so it seems. i will try playing with the wires i might get lucky.
and yeah removing the seat wont help
and thanks winchman i might need to make a small cut to take a close look at this
Old Oct 6, 2011 | 06:52 AM
my friend's Avatar
my friend
ok great news i got the door open but the process i broke a pink plastic clip that connects the linkage. do you guys think the dealership will have it or do i need to order a new door handle?
Old Oct 6, 2011 | 08:35 AM
winchman's Avatar
winchman
So, how did you get the door open?
Old Oct 6, 2011 | 11:04 AM
my friend's Avatar
my friend
well first i lowered the window all the way down then i pried on the lower part of the weather strip. this allowed me to move the door cover about half an inch i looked inside and located the linkage and yanked on it with a coat hanger. once the linkage was separated i was able to open the door from the inside. and i removed the door handle and noticed that pink clip broke in the process. THE END
Old Dec 6, 2011 | 06:33 PM
dudegetalife's Avatar
dudegetalife
Just had this happen what linkage are you talking about exactly so i dont break something?
Old Jan 10, 2025 | 12:26 PM
350zf250's Avatar
350zf250
Did you figure it out i am having the same problem?
Old Jan 10, 2025 | 04:04 PM
travlee's Avatar
travlee
Master
He hasn't logged in since 2018, and this thread is from 2011
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Justin100
Nov 29, 2015 03:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
