Brake, VDC off and slip light on
Old Jun 4, 2011 | 10:49 AM
blktrack350's Avatar
blktrack350
Default Brake, VDC off and slip light on
Like the title says they come on randomly. Could be right when I turn on my car or 15 min later and then stay on. And some times the brake light will turn off while the other 2 lights stay on. Last time this happened it was because I had to change my brake pads. But all pads are good, brake fluid at a good level and all my fuses are good. So if anyone could tell me some the things to check that would be perfect. I have a 2003 with 83000 miles if that matters
Old Jun 8, 2011 | 07:08 AM
blktrack350
No help at all?
Old Jun 8, 2011 | 07:39 AM
Russ@Z1's Avatar
Russ@Z1
Try checking the abs system for error codes.
Mine through the code for the abs pressure switch, but it turned out to be a worn $35 brake light switch under the brake pedal which was causing my VDC, ABS, and SLIP lights.
Other reasons could be a ABS wheel sensor out of alignment or failing.
Old Jun 8, 2011 | 07:51 AM
Johnnyone's Avatar
Johnnyone
I know mine come on when i go drifting and when they come on, i turn off the car for like a minute turn it back on and Im good to go.
Subscribed to see how to fix this and if there are any issues with driving with these lights on.
Old Jun 21, 2011 | 07:37 AM
JERZ350's Avatar
JERZ350
I would have suggested exactly what you already did, brake fluid level. Exact same issue for me when my fluid was low due to worn pads. The fluid was only slightly low, so it's pretty picky, I made sure it was filled near the Max line. Lights never came back on.
Old Jun 21, 2011 | 01:56 PM
ffwturboZ's Avatar
ffwturboZ
I had the same issue and it eneded up being the cam angle sensors and crank sensor. I took the car to the stealership for a diagnostic (75.00) and they gave me a print out of the findings. I went and bought the sensors and put them on myself... ualaahhh.. no more lights!!
350z82
Oct 1, 2015 06:25 PM
